LTspice: MPPT solar cell string with DC-DC buck converter
pann11
Joined Mar 14, 2016
I have a LTspice simulation model containing a solar cell string connected to a dc-dc converter. The output of the solar cell string is the input of the converter. Attached is a simplified schematic of the circuitry.
I want to implement maximum power point tracking (MPPT) to the solar cell string to fix the maximum power point on the IV curve of the solar cells.
I've tried this with a voltage source (V_mpp) parallel to the solar cell string for which I set the voltage equal to V_mpp (for a string of 6 regular cells this is about 2.7V). I've tried to work with the resistance of V_mpp, from zero to 1Gohm, but with mixed results.
Is there another way to implement a MPPT logic in LTspice such that I can lock Impp and Vmpp of the IV curve of the solar cell string? solarcells_mppt_converter.png
Best regards,
Boudewijn
Alec_t
Joined Sep 17, 2013
15,152
Does the buck converter have a fixed output voltage?
Is the load fixed? If so, what happens when the cells generate more power than the load demands?
