LTSpice Models for TIP100/101/102 and TIP105/106/107.
elec_eng_55
Joined May 13, 2018
214
Hello:
Does anyone have LTSpice models for TIP100/101/102 and TIP105/106/107?
I haven't been able to find any that worked.
Thanks,
David
eetech00
Joined Jun 8, 2013
4,744
Hello:
Thanks,
David
Hi
You can get them all at OnSemiconductor.
The ones I tested (TP100, TP101) worked fine..
The model definitions are .subckts, so after you place a symbol on the schematic, you have to change the "Prefix" property to an "X", without the double quotes. Also add the ".inc TP100.LIB" statement on the schematic.
eT
elec_eng_55
Joined May 13, 2018
214
Hi
eT
Thanks eT
elec_eng_55
Joined May 13, 2018
214
Hi Bordodynov:
I copied the TIP100 and TIP105 into the "sub" in "documents". I also copied
the "npndarl1 " and "pnpdarl2" into the "sym" folder. I then added the "npndarl1"
symbol to a schematic and added the following directive ".inc TIP100.lib" to
the schematic. The "x" was already there and I set the value to "TIP100". It
didn't work for me. I have messed it up somehow.
I am now lost.
David
Bordodynov
Joined May 20, 2015
3,431
You didn’t like my Symbol. And you indicated the wrong library. By putting one of my symbols on a diagram, you have access to several parts. I showed it. It is not necessary to mention the name inside the symbol twice.
elec_eng_55
Joined May 13, 2018
214
I have now set up the TIP101 darlington transistor symbol and sub-circuit and added
the TIP101 to a CE voltage amplifier. The voltage gain is only 2.5. Something is wrong
with my circuit. There is only a 0.7V drop from base to emitter. I would have expected
a 1.4V drop. Is it only 0.7V due to the TIP101's internal diode?
Bordodynov
Joined May 20, 2015
3,431
You use a powerful transistor on a small current. In this case, the second, internal, powerful transistor is closed. Reduce the resistors in the emitter and collector 100 times and you will get a gain of 3.7 (almost 4)
