I have spent hours trying to figure out why my MCP6V11 model doesn't work. I keep getting this error: "Analysis: Time step too small; initial timepoint: trouble with node u1:15".
It appears that a lot of people have a similar problem with the Microchip SPICE model, but I haven't found any solid solution for it.
Please let me know if you have any recommendations?
Below is the MCP6V11_F.txt model that I downloaded directly from Microchip, then renamed it MCP6V11.sub:
.SUBCKT MCP6V11 1 2 3 4 5
* | | | | Output
* | | | Negative Supply
* | | Positive Supply
* | Inverting Input
* Non-inverting Input
* Software License Agreement *
* The software supplied herewith by Microchip Technology Incorporated (the *
* 'Company') is intended and supplied to you, the Company's customer, for use *
* soley and exclusively on Microchip products. *
* The software is owned by the Company and/or its supplier, and is protected *
* under applicable copyright laws. All rights are reserved. Any use in *
* violation of the foregoing restrictions may subject the user to criminal *
* sanctions under applicable laws, as well as to civil liability for the *
* breach of the terms and conditions of this license. *
* THIS SOFTWARE IS PROVIDED IN AN 'AS IS' CONDITION. NO WARRANTIES, WHETHER *
* EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED *
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO *
* THIS SOFTWARE. THE COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR *
* SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER. *
* The following op-amps are covered by this model:
* MCP6V11/1U/2/4
* Date of model creation: 9-6-2019_8:38:50_PM
* Level of Model Creator: 6V11_01S / 08-08-19
* Revision History:
* REV A: 17-May-12, Initial Input / REV B: 09-Jul-12, Added MCP6V11U
* REV C: 07-JuL-17, Updated Model Creator 6.14S
* REV D: 24-JuL-17, Updated Rout, Vos, and Vos Drift
* REV E: 08-Aug-19, Updated Output Impedance, Slew Rate plus characterization
* REV F: 06-Sep-19, Removed buffer in Gain/Phase test ckt, adjusted response to match original bode plot. Updated 1/f noise.
* Recommendations:
* Use PSPICE (or SPICE 2G6; other simulators may require translation)
* For a quick, effective design, use a combination of: data sheet
* specs, bench testing, and simulations with this macromodel
* For high impedance circuits, set GMIN=100F in the .OPTIONS statement
* Supported:
* Typical performance for temperature range (-40 to 125) degrees Celsius
* DC, AC, Transient, and Noise analyses.
* Most specs, including: offsets, DC PSRR, DC CMRR, input impedance,
* open loop gain, voltage ranges, supply current, ... , etc.
* Temperature effects for Ibias, Iquiescent, Iout short circuit
* current, Vsat on both rails, Slew Rate vs. Temp and P.S.
* Not Supported:
* Some Variation in specs vs. Power Supply Voltage
* Vos distribution, Ib distribution for Monte Carlo
* Distortion (detailed non-linear behavior)
* Some Temperature analysis
* Process variation
* Behavior outside normal operating region
* Known Discrepancies in Model vs. Datasheet:
* Input Stage
V10 3 10 -400M
R10 10 11 69.0K
R11 10 12 69.0K
G10 10 11 10 11 1.44M
G11 10 12 10 12 1.44M
C11 11 12 76.8P
C12 1 0 6.00P
E12 71 14 VALUE { (646N) + V(20) * 17.4 + V(21) * 17.4 + V(22) * 17.4 + V(23) * 17.4 }
* Generate Input Bias 1 and 2 and Input Offset
EG12 VIBIAS 0 62 0 1
EG13 VIBIOS 0 63 0 1
* Calculate IB1 and IB2 based on IOS
EIB1 VIB1 0 VALUE { (V(VIBIAS)+V(VIBIOS)) /2 }
EIB2 VIB2 0 VALUE { (V(VIBIAS)-V(VIBIOS)) /2 }
* Convert Voltage to Current on Pins 1 and 2
GIB1 1 0 VIB1 0 1u
GIB2 2 0 VIB2 0 1u
M12 11 14 15 15 NMI
M14 12 2 15 15 NMI
C14 2 0 6.00P
I15 15 4 500U
V16 16 4 -150M
GD16 16 1 TABLE { V(16,1) } ((-100,-100E-15)(0,0)(1m,1u)(2m,1m))
V13 3 13 -200M
GD13 2 13 TABLE { V(2,13) } ((-100,-100E-15)(0,0)(1m,1u)(2m,1m))
R71 1 0 10.0E12
R72 2 0 10.0E12
R73 1 2 10.0E12
*C13 1 2 3.00P
* Noise
I20 21 20 423U
D20 20 0 DN1
D21 0 21 DN1
I22 22 23 1N
R22 22 0 1k
R23 0 23 1k
* Open Loop Gain, Slew Rate
G30 0 30 12 11 1
R30 30 0 1.00K
G31 0 31 3 4 5.69
I31 0 31 DC 33.2
R31 31 0 1
E_VDDMAX VDE 0 3 4 1
V_VDD1 31VDD1 0 1.6
V_VDD2 31VDD2 0 5.5
G_ABMII2 0 31B VALUE { V(31)*(LIMIT(((V(31VDD1)-V(VDE))/(V(31VDD1)-V(31VDD2))), 0, 1))}
R_R3 31A 0 1 TC=3.39M, -15.3U
G_ABMII1 0 31A VALUE { V(31)*(LIMIT(((V(VDE)-V(31VDD2))/(V(31VDD1)-V(31VDD2))), 0, 1))}
G_G6 30 31C TABLE { V(30, 31C) } ((-100,-1n)(0,0)(1m,0.1)(101m,190.1))
E_ABM1 31C 0 VALUE { (V(31A) + V(31B)) }
R_R8 31B 0 1 TC=3.15M, -21.4U
G32 32 0 3 4 11.3
I32 32 0 DC 39.6
R32 32 0 1
G_ABMII22 32B 0 VALUE { V(32)*(LIMIT(((V(31VDD1)-V(VDE))/(V(31VDD1)-V(31VDD2))), 0, 1))}
R_R23 32A 0 1 TC=2.98M, -14.0U
G_ABMII21 32A 0 VALUE { V(32)*(LIMIT(((V(VDE)-V(31VDD2))/(V(31VDD1)-V(31VDD2))), 0, 1))}
G_G26 32C 30 TABLE { V(30, 32C) } ((-101m,190.1)(-1m,0.1)(0,0)(100,-1n))
E_ABM21 0 32C VALUE { (V(32A) + V(32B)) }
R_R28 32B 0 1 TC=2.33M, -15.4U
G6 0 33 30 0 1m
R6 33 0 1K
* 1st Order Pole
G34 0 34 33 0 6.31
R34 34 0 1K
C34 34 0 10.6M
* 2nd Order Pole
G37 0 37 34 0 1m
R37 37 0 1K
C37 37 0 318P
* 3rd Order Pole
G377A 0 377A 37 0 1m
R377A 377A 0 1K
C377A 377A 0 795N
* 1st Order Zero
G38 0 38 377A 0 1m
GR38 39 0 39 0 1m
RR38 39 0 100G
L38 38 39 7.95M
E38 35 0 38 0 1
* Output Stage
R80 50 0 100MEG
G50 0 50 57 96 2
R58 57 96 0.50
R57 57 57A 10k
LR14 57 57A 79.6M
RR14 57A 0 100
* PSRR / CMRR
G57 0 57 VALUE { V(35) * 10.0M + V(118) + V(127) + V(137) }
* PSRR Plus Gain and GBWP Pole Neutralization and Wave Shaping
* G30 THE DC GAIN FOR +PSRR
G110 0 110 3 0 11.2U
* ADD POLE TO NEUTRALIZE GBWP ZERO
R110 110 0 1G
GR110 110 0 110 0 1M
C110 110 0 10.6M
* PSRR Plus Pole
G111 0 111 110 0 1
L111 111 112 17.6
R112 112 0 1G
GR112 112 0 112 0 1
* PSRR Plus Zero
G114 0 114 111 0 1
R114 114 0 1G
C114 114 0 795U
GR114 114 0 114 0 1
* PSRR Plus 2nd Pole
G115 0 115 114 0 1
L115 115 116 159P
R116 116 0 1G
GR116 116 0 116 0 1
* PSRR Plus 2nd Zero
G117 0 117 115 0 1
R117 117 0 1G
C117 117 0 159P
GR117 117 0 117 0 1
* PSRR Plus 3rd Pole
G118 0 118 117 0 1
L118 118 119 159P
R119 119 0 1G
GR119 119 0 119 0 1
* PSRR Minus Gain and GBWP Pole Neutralization and Wave Shaping
* G40 THE DC GAIN FOR -PSRR
G120 0 120 4 0 11.2U
R120 120 0 1G
GR120 120 0 120 0 1M
C120 120 0 10.6M
* PSRR Minus Pole
G121 0 121 120 0 1
L121 121 122 17.6
R122 122 0 1G
GR122 122 0 122 0 1
* PSRR Minus Zero
G124 0 124 121 0 1
R124 124 0 1G
C124 124 0 795U
GR124 124 0 124 0 1
* PSRR Minus 2nd Pole
G125 0 125 124 0 1
L125 125 126 159P
R126 126 0 1G
GR126 126 0 126 0 1
* PSRR Minus 2nd Zero
G1217 0 127 125 0 1
R127 127 0 1G
C127 127 0 159P
GR127 127 0 127 0 1
* CMRR Gain and GBWP Pole Neutralization and Wave Shaping
* G50 THE DC GAIN FOR CMRR
G130 0 130 VALUE { ( V(15) ) * 10.0U}
* Add Zero To Neutralize GBWP Pole
R130 130 0 1G
GR130 130 0 130 0 1m
C130 130 0 15.0M
* CMRR Pole
G131 0 131 130 0 1
L131 131 132 2.65
R132 132 0 1G
GR132 132 0 132 0 1
* CMRR Zero
G133 0 133 131 0 1
R133 133 0 1G
C133 133 0 795U
GR133 133 0 133 0 1
* CMRR 2nd Pole
G134 0 134 133 0 1
L134 134 135 7.96U
R135 135 0 1G
GR135 135 0 135 0 1
* CMRR 2nd Zero
G137 0 137 134 0 1
R137 137 0 1G
C137 137 0 39.7U
GR137 137 0 137 0 1
GD55 55 57 TABLE { V(55,57) } ((-0.2m,-400)(-0.1m,-1m)(0,0)(10,1n))
GD56 57 56 TABLE { V(57,56) } ((-0.2m,-400)(-0.1m,-1m)(0,0)(10,1n))
C555 55 57 1P
C557 57 56 1P
E55 55 0 VALUE { 600U + V(3) * 1 + V(51) * -56.0M }
E56 56 0 VALUE { -577U + V(4) * 1 + V(52) * -45.7M }
R51 51 0 1k
R52 52 0 1k
GD51 50 51 TABLE { V(50,51) } ((-10,-1n)(0,0)(1m,1m)(2m,1))
GD52 50 52 TABLE { V(50,52) } ((-2m,-1)(-1m,-1m)(0,0)(10,1n))
G53 3 0 VALUE { -500U + V(51) * 1M }
G54 0 4 VALUE { -500U + V(52) * -1M }
* Current Limit
G99 96 5 99 0 1
R98 0 98 1 TC=-7.05M,19.9U
G97 0 98 TABLE { V(96,5) } ((-11.0,-8.00M)(-1.00M,-7.92M)(0,0)(1.00M,7.92M)(11.0,8.00M))
E97 99 0 VALUE { V(98) * LIMIT((( V(3) - V(4) ) * 357M + 107M), 0.00, 1E6 ) * LIMIT((( V(3) - V(4) ) * 400M + 0.00), 0, 1) }
D98 4 5 DESD
D99 5 3 DESD
* Temperature / Voltage Sensitive IQuiscent
R61 0 61 1 TC=2.70M,-7.11U
G61 3 4 61 0 1
G60 0 61 TABLE { V(3, 4) } ((0, 0)(500M,61.0N)(1.5,5.6U)(2.5,5.8U)(3.5,6.00U)(4.5,6.1U)(5.5,6.2U))
* Temperature Sensitive offset voltage
I73 0 70 DC 1
R74 0 70 1 TC=5.00N
E75 1 71 VALUE {V(70)-1}
* Temp Sensistive IBias
I62 0 62 DC 1uA
R62 622 62 REXP 4.73598
R622 0 622 REXP_2 83.17738U
* Temp Sensistive Offset IBias
I63 0 63 DC 1uA
R63 633 63 REXP2 50.54068
R633 0 633 REXP_4 150.72187M
G57X 0 57X VALUE { V(35) * 10.0M + V(118) + V(127) + V(137) }
R57X 57X 57AX 10k
LR14X 57X 57AX 79.6M
RR14X 57AX 0 100
G35X 33 0 TABLE { V(57X,3) } ((-1,-1p)(0,0)(500M,1n)(1.00,1))
G36X 33 0 TABLE { V(57X,4) } ((-1.00,-1)(-500M,-1n)(0,0)(1,1p))
* Models
.MODEL NMI NMOS(L=2.00U W=42.0U KP=200U LEVEL=1 )
.MODEL DESD D N=1 IS=1.00E-15
.MODEL DN1 D IS=1P KF=14.6E-20 AF=1.3
.MODEL REXP RES TCE= 1.3865
.MODEL REXP_2 RES TCE= 17.84466
.MODEL REXP2 RES TCE= 540.46288M
.MODEL REXP_4 RES TCE= 7.82344
.ENDS MCP6V11
* | | | | Output
* | Inverting Input
* MCP6V11/1U/2/4
* Revision History:
* Recommendations:
* Supported:
* Not Supported:
* Process variation
* Input Stage
V10 3 10 -400M
R10 10 11 69.0K
R11 10 12 69.0K
C11 11 12 76.8P
C12 1 0 6.00P
GIB1 1 0 VIB1 0 1u
GIB2 2 0 VIB2 0 1u
M12 11 14 15 15 NMI
M14 12 2 15 15 NMI
C14 2 0 6.00P
I15 15 4 500U
V16 16 4 -150M
V13 3 13 -200M
R71 1 0 10.0E12
R72 2 0 10.0E12
R73 1 2 10.0E12
*C13 1 2 3.00P
* Noise
I20 21 20 423U
D20 20 0 DN1
D21 0 21 DN1
I22 22 23 1N
R22 22 0 1k
R23 0 23 1k
G30 0 30 12 11 1
R30 30 0 1.00K
G31 0 31 3 4 5.69
I31 0 31 DC 33.2
R31 31 0 1
V_VDD1 31VDD1 0 1.6
V_VDD2 31VDD2 0 5.5
G32 32 0 3 4 11.3
I32 32 0 DC 39.6
R32 32 0 1
G6 0 33 30 0 1m
R6 33 0 1K
* 1st Order Pole
G34 0 34 33 0 6.31
R34 34 0 1K
C34 34 0 10.6M
* 2nd Order Pole
G37 0 37 34 0 1m
R37 37 0 1K
C37 37 0 318P
* 3rd Order Pole
R377A 377A 0 1K
C377A 377A 0 795N
* 1st Order Zero
G38 0 38 377A 0 1m
GR38 39 0 39 0 1m
RR38 39 0 100G
L38 38 39 7.95M
E38 35 0 38 0 1
* Output Stage
R80 50 0 100MEG
G50 0 50 57 96 2
R58 57 96 0.50
R57 57 57A 10k
LR14 57 57A 79.6M
RR14 57A 0 100
* PSRR / CMRR
R110 110 0 1G
C110 110 0 10.6M
* PSRR Plus Pole
G111 0 111 110 0 1
L111 111 112 17.6
R112 112 0 1G
GR112 112 0 112 0 1
* PSRR Plus Zero
G114 0 114 111 0 1
R114 114 0 1G
C114 114 0 795U
GR114 114 0 114 0 1
G115 0 115 114 0 1
L115 115 116 159P
R116 116 0 1G
GR116 116 0 116 0 1
G117 0 117 115 0 1
R117 117 0 1G
C117 117 0 159P
GR117 117 0 117 0 1
G118 0 118 117 0 1
L118 118 119 159P
R119 119 0 1G
GR119 119 0 119 0 1
R120 120 0 1G
C120 120 0 10.6M
* PSRR Minus Pole
G121 0 121 120 0 1
L121 121 122 17.6
R122 122 0 1G
GR122 122 0 122 0 1
* PSRR Minus Zero
G124 0 124 121 0 1
R124 124 0 1G
C124 124 0 795U
GR124 124 0 124 0 1
G125 0 125 124 0 1
L125 125 126 159P
R126 126 0 1G
GR126 126 0 126 0 1
G1217 0 127 125 0 1
R127 127 0 1G
C127 127 0 159P
GR127 127 0 127 0 1
R130 130 0 1G
C130 130 0 15.0M
* CMRR Pole
G131 0 131 130 0 1
L131 131 132 2.65
R132 132 0 1G
GR132 132 0 132 0 1
* CMRR Zero
G133 0 133 131 0 1
R133 133 0 1G
C133 133 0 795U
GR133 133 0 133 0 1
* CMRR 2nd Pole
G134 0 134 133 0 1
L134 134 135 7.96U
R135 135 0 1G
GR135 135 0 135 0 1
* CMRR 2nd Zero
G137 0 137 134 0 1
R137 137 0 1G
C137 137 0 39.7U
GR137 137 0 137 0 1
C555 55 57 1P
C557 57 56 1P
R51 51 0 1k
R52 52 0 1k
* Current Limit
G99 96 5 99 0 1
D98 4 5 DESD
D99 5 3 DESD
G61 3 4 61 0 1
I73 0 70 DC 1
R74 0 70 1 TC=5.00N
I62 0 62 DC 1uA
I63 0 63 DC 1uA
R57X 57X 57AX 10k
RR14X 57AX 0 100
* Models
.ENDS MCP6V11
