Interesting observations. Of the things we've tried so far, the one that worked the best was a Corcom filter. The particular one we tried wasn't enough, but we're definitely going to try a few others with more suitable frequency response characteristics for what we need. Ideally we'd like to integrate a solution into our board, not use a separate filter module, but we may end up modeling our approach on one of theirs.Wouldn't you need some capacitors between each phase and ground?
I'm not sure what you need exactly, but when I had some EMI problems, I used something from these guys (Corcom). They have circuit diagrams for their products, which had capacitors between the phases like you did, but also had capacitors between each phase and ground after the common mode choke.
Also - if you were going to copy one of the Corcom designs, on theirs, you would want your capacitor that ties the phases together on the other side of the common mode choke, and the capacitors to ground on the side of the choke that your phase-to-phase capacitor is now ...
