LTspice chain of LC resonators
Partyzoa
Joined Apr 9, 2017
Dear all,
I am new to this forum and I really hope I posted this into the right place.
On a way to solve a problem for my mathematical-physics class I tried to solve simple circuit with LTspice (picture below).upload_2017-4-9_20-29-24.png
As a result I get 0V everywhere. What is wrong?
Thank you for your time!
Partyzoa
Joined Apr 9, 2017
Hello again,
Thank you but something is still not working;
I selected skip initial operating point solution and this showed:
WARNING: Node N003 is floating.
Per .tran options, skipping operating point for transient analysis.
Singular matrix: Check node n002
Iteration No. 1
Fatal Error: Singular matrix: check node n002
Iteration No. 1
This circuit has floating nodes.
Hope I did everything correct. Thank you for your time again!
38,909
I had problems with the simulation also. I could not get it to work as Bordodynov did.
It appears to not like setting initial current in an inductor in series with a capacitor.
So in my simulation below I added switches to momentarily short the capacitor at the start of the simulation.
The simulation then seems to work normally.
