I would like to generate a signal within the subcircuit using the PWL command. One of the input variables is going to continuously change in the simulation. So, I am using an input "Vin" just to pass this information to the subcircuit. I wanted to generate a PWL command, where the voltage & time variables are needed. Is it possible to pass the node voltage as a variable using ".Param" command? Something like what I am showing in the picture? It does not work, so I am wondering if you have ideas or workarounds.
