Hi Eric,hi p2p.
The link does not give the circuit design within the Yellow box area.
I am not paying $90 for the model, do you have a free Copy.?
E
@p2p
Have you seen this link?
https://www.analog.com/en/technical...del-for-current-mode-dc-to-dc-converters.html
And this PDF.
Given its DC to DC, why are you inputting a sine wave?I will make a frequency-independent DC/DC converter that I will use in my homework. I calculated the efficiency of the module I will use according to the current I will draw. I will make this circuit subcircuit and enter 4 external parameters. IN_MAX IN_MIN VOUT EFFICIENCY
I was testing max min voltages.Given its DC to DC, why are you inputting a sine wave?
