vandveuser16776
- Joined Feb 21, 2026
- 231
How so?the idea of putting in a diode instead of a mechanical switch is a novel approach and works great for the discharge phase. But when I started thinking about the concept in that circuit, I realized it causes a voltage divider to be introduced into the charging phase and skews the charging curve accordingly.
Are they? Looking at the curve I see ~8.3V charged in the first second of the charging phase and ~6.3V discharged in the first second of the discharging phase? I'm missing something here... Shouldn't that be...Note that the capacitor charge and discharge times are essentially the same
That's not because of any voltage divider action.?
No! I see it now, the period τ has changed in the discharge phase due to the addition of the R1 resistor to ground! OK, I misinterpreted the graph. But ONLY R2 is involved in the charging of the capacitor. I played a bit with the circuit in LTS and what appeared to me as a voltage divider is NOT. Both resistors go to ground and they do affect the charge and discharge rates, but the voltage on the capacitor is always the same! OK, I have it now, Thanks!
I understand that real models require actual measured values, but these close approximations are all that I'm looking for here. Much easier to let the software draw the curves than doing all the calculations and plotting the results!if you want simulations that match your hand calculations very closely
My brain was playing tricks on me. It's not even a series divider circuit but a simple parallel one with the voltage across both resistors.That's not because of any voltage divider action.
No, I hadn't thought to look in Wiki for it. Thanks for the heads up! When I finally found the LTS help page on the Analog site that @eetech00 pointed me to it helped clear up a lot of questions also!Are you aware of the LTS info on this link?
