I am trying to understand how to modify the circuit below to output ~180V at 4mA minimum for a multiplexed nixie design.
Voltage:
The 1:12 transformer is being replaced with a 1:10 coupled inductor, which should drop the voltage right off the bat. Modifying the resistors connected to the FB pin for a specific voltage should allow the IC to regulate the output voltage by changing its duty cycle, though only within a certain range. It appears the upper right portion of the circuit is a voltage multiplier, so could that be modified to drop the voltage?
Current:
I don't know how to go about modifying the current capabilities. My guess would be that it bottlenecks somewhere, since other 'Typical Application' circuits in the datasheet can handle much higher current loads.
David Forbes' nixie watch uses one of these ICs in his schematic, though it is the B variant. There are several forums in which he says one of these can output up to 4mA, but I don't know how to achieve this output.
Voltage:
Current:
