Question:
Consider the circuit below in which R1=R2=2Ω. Select C and L to obtain a resonant frequency of 150rad/s.
Attempt:
First I try to find the equivalent impedance:
\(Z = wLj + 1 + \frac{1}{wCj + 1}
= wLj + 1 + \frac{1-wCj}{w^2C^2 + 1}
= 1 + \frac{1}{w^2C^2+1} + wj(L - \frac{C}{w^2C^2+1})
= \frac{2 + w^2C^2 + jw[(L-C)+w^2LC^2]}{w^2C^2+1}\).
This is where i'm not sure what to do next. In the book I am reading from it only covers resonance for parallel LRC loads connected to a current source and series LRC loads connected to a voltage source. In both of those the ω term only appears in the imaginary part so you just set that equal to zero to maximize the magnitude of the transfer function and find the resonant frequency.
I read on Wikipedia that the resonant frequency is the one at which the reactance is zero, which was indeed true in the two simple cases in my book, but I don't understand why this is the condition for resonance. Surely the important thing is to maximize the magnitude of the transfer function?
For example, for the circuit above, say the input was a current source and the output was the capacitor voltage. Then the transfer function is just Z, so my first thought would be that I need to find |Z|, then differentiate this wrt ω and set this to zero to find the maximum? But I don't need to do this? I can just find the ω that makes the reactance zero and i'm done? Why does this ω neccessarily maximize |Z|?
Thanks for your help!
Attempt:
