LP0701 P channel FET drive problem from ICM7242 timer
elandri
Joined Aug 22, 2020
43
Yes...but there is a race condition between trigger and power-up. The trigger happens too fast.
Datasheet say that it powers up not triggered. The RC network on the trigger pin is meant to delay trigger by 100ms to enable stable power up. It is triggering so doing what I need in that respect. What's the implication with "too fast"?
elandri
Joined Aug 22, 2020
43
I was getting to that myself. Did you reverse the RC network?
SG
Not yet. I was worried I might be not able to get the timer started but it is starting so I'm not to concerned about that bit!
I'll go and redo things for an opto-coupler and see how that goes.
Will post an update when I have more news.
Many thanks
elandri
Joined Aug 22, 2020
43
Isolates the SET switch so only the chip activates the load.
SG
Built your circuit using a Vishay TO14642 opto which has very similar characteristics to the CPC1008N (but lower Ron).
Timer aspect works fine but getting much the same problem as we had with the FET - When timer o/p goes high it doesn't go high enough to turn off the diode so the derived Vcc goes down but not off and we are still drawing 1.6mA from supply.
Playing around, I tried two and then three diodes in series. Each addition reduces the derived Vcc slightly.
Interesting, with three diodes in I'm seeing Vcc of 0.87V, 1.17V on pin 3 (o/p) and 2.26 on the cathode of the opto LED (3.33V on the anode).
If I remove the link from o/p to opto and hold SET to provide Vcc to cct o/p returns to 3.33V after the timing period.
I'm mighty confused now!
elandri
Joined Aug 22, 2020
43
Have tried that too. I went to the AC/DC connections to eliminate any possibility of being wrong:)
I usually use these with GND to pin 5 so seems logical that in high side use pins 4 and 6 would be the more +ve.
sghioto
Joined Dec 31, 2017
8,659
OK I think the problem is in the ICM7242. When no power is applied there is some residual resistance on the output pin which is causing the opto to stay on. Seen this before in other chips. Give me a few minutes and I'll come up with something.
SG
elandri
Joined Aug 22, 2020
43
In the meantime I've just removed the link from the opto o/p to the cct and powered the circuit direct from PSU.
The timer now correctly resets the opto led if directly attached (cathode to 3.33V). With the diode in cct the opto cathode only goes to 2.4V so I suspect will still be partially on.
