I'd whipped the attached up earlier in Circuitmaker Student, which is obsolete/no longer supported, but has a smattering of IC's and transistors that have been popular over the last 30 years or so.
It's different from what RonH came up with, but I suppose that's to be expected - there's always a number of different ways to skin the proverbial cat.
One problem you may run into with this version is the average input voltage; if there's a very long string of "10101010.." that eventually changes to "010101..", the waveform won't be centered around the 0v level; it'll be centered around the average voltage level whereas ideally it should be centered on P-P/2.
This version also doesn't allow for differences in threshold levels for the comparators; it depends upon the higher slew rate from the amplified signal to trip the comparators in a reasonably short amount of time.
