Low pass Filter for Square wave
balaji selva
Joined Nov 29, 2013
20
is there a low pass analog filter for square wave which does not cause ringing effect or conversion to sine wave.....
or please say which is best filter for square wave...
if so please give the circuit diagram of that filter...
35,178
For the op, you can create a low-pass filter using an inductor or a resistor and capacitor.
But first, you have to say why you want to filter a square wave. What do you expect to happen?
LvW
Joined Jun 13, 2013
2,037
I suppose you need something like a Bessel response?
This lowpass filter is intended to preserve the squarewave form.
SgtWookie
Joined Jul 17, 2007
22,230
The first concept that you must grasp, is what, exactly, makes up an ideal square wave?
An ideal square wave is comprised of the fundamental frequency, plus ALL of the ODD harmonics of that fundamental frequency. Thus, an ideal square wave requires UNLIMITED bandwidth. Since unlimited bandwidth is not practical/possible to achieve in a real physical system, we have to settle for approximations of an ideal square wave.
If you run an ideal square wave through a low-pass filter, it will no longer be a square wave.
Have a look at the animations in the Wikipedia entry for Square_wave:
http://en.wikipedia.org/wiki/Square_wave
#12
So, basically, there is no such thing as a square wave with only low frequency components. If you want a useful answer, you will have to tell us, how low do you want to go and how distorted can you put up with?
