low output voltage
sudhir hora
Joined Jun 7, 2023
hi there, I have a power supply of 18volt /5.5 amp.the fault is it gives 4 volt instead of 18 volt ,when I checked all the components 39E resistance and 1148 diodes were open ,I replace these components but still the fault is same.supply works with 2× 13009 transistor. please help20230607_171539.jpg
Alec_t
Joined Sep 17, 2013
15,149
Welcome to AAC!
The area around the fuse F1 and its link LF1 looks scorched. Check that the fuse is ok and that there are no dry/loose solder joints in that area.
sudhir hora
Joined Jun 7, 2023
Welcome to AAC!
thanks but I've checked all..the output is 4 volts ,but not 18 , I've checked all capacitors, diodes,but the output is same at 4 volts
sarahMCML
Joined May 11, 2019
703
hi there, I have a power supply of 18volt /5.5 amp.the fault is it gives 4 volt instead of 18 volt ,when I checked all the components 39E resistance and 1148 diodes were open ,I replace these components but still the fault is same.supply works with 2× 13009 transistor. please helpView attachment 295951
That device clamped to the heatsink, just above the blue electrolytic capacitor, in the second photo from the right, is split open. It must be damaged and will need replacing, There may be others.
Ya’akov
Joined Jan 27, 2019
10,282
The trace under A looks very dodgy, is there continuity?
The area under B looks like is might have been a trace that is now gone, was there copper there?
sudhir hora
Joined Jun 7, 2023
n
at point B tere was a water spillage between mains fuse and feedback 1148 diode in series with 39E resistance. both are open .I replace them both.but the problem is when both are open the supply was on at 4 volt output,when I replace them ,the supply still gives 4 volt output.13009 in pair are both ok.the feedback transformer didn't give output at 1148 diode ,
Ya’akov
Joined Jan 27, 2019
10,282
n
OK, but this appears to be a single sided PCB so all the traces that are required would be on the bottom. If there are missing or open traces, things won’t work. I am not clear about your answer: is there continuity at A? Was there a trace at B that is now gone?
sudhir hora
Joined Jun 7, 2023
it is a silicon tube that I cut to check the transistor 13009 in pair clamped with heating,,both transistor ok but I replace them ,,still not working and stuck on 4 volts,,
