Looking formation on whole-house audio -- specifically impedance matching.
the.doc
Joined Jan 22, 2021
15
I've done lots of internet searches looking for information about how impedence-matching volume controls work. Never found a thing beyond the fact that some of these things use auto-transformers, and some are purely resistive (e.g. L-pads). The problem I have is when you have several rooms, each with its own volume control, and all this is wired in parallel to the amplifier outputs. The cheap solution seems to be to put a 4-ohm power resistor in series with the speakers to limit the load on the amp. The house I'm looking at has 18 speakers; each of them has a woofer and a tweeter and a crossover, which means that wiring some of them in series is out; so they are all in parallel, which is less than 1/2 ohm. The 4-ohm series resistor saves the amp but also dissipates something like 90% of the amps output power.
If somebody can point me to some places that I can read about how this stuff works, I'd greatly appreciate it.
thanks
38,947
Some of the auto-transformer type controls have jumper settings for the number of speakers (here for example).
It has settings for different amplifier and speaker impedance ratings, as well as the number of speakers.
For example, the maximum number of 8 ohm speakers for a 4 ohm amplifier is 16, but if you have a decent amplifier, it should readily tolerate the slightly lower impedance (≈3.56Ω) 18 speakers would make.
Seems like overkill for just a house audio system. :rolleyes:
The guy has 18 speakers. Driving that from a single audio source in 2022 is like driving a model-a car. It works but is several gens behind even 2010 technology. I would maybe look at wireless if the OP wants modern whole house technology instead of systems tied to old limited 70 volt tapped transformer technology.
Audioguru again
Joined Oct 21, 2019
6,826
Woofers, tweeters and crossovers were stated so hifi is probably wanted.
The cheap autotransformer has absolutely no audio specs so its lows and highs are probably missing and it probably produces plenty of distortion. Boomy bass like a bongo drum due to poor damping?
Audioguru again
Joined Oct 21, 2019
6,826
I did not see the pretty good frequency response spec before.
Its unknown amount of distortion is hidden and there is no mention of losses or damping.
The output impedance of a modern amplifier is never matched, it is much lower than the load for good damping of speaker resonances. Antique toobs (valves) amplifiers had a higher output impedance that matched the speaker impedance.
38,947
The damping is just a function of the impedance transformation of the control.
So if it's set to match the impedance of sixteen 8-ohm speakers in parallel to a 4 ohm amplifier output, the transformation factor from amp to speaker is 1:8.
The damping factor seen by the speaker would thus be increased by that same value.
the.doc
Joined Jan 22, 2021
15
Agreed. The house belongs to the son of some good friends of mine. It has Leviton SGC65 ceiling speakers in a number of rooms all driven by a Sonos Amp. All of the rooms have local volume controls; 2 are of the autotransformer type and 3 are Leviton SGSVT (no transformers, no impedance matching) connected to the amplifier through a Leviton SGAMP System Matching Module which has a "Transformer-Free impedance-matching design". Each room is fed by a single pair of conductors from the amplifier, so there is no stereo. There is also an Episode speaker selector with "Amplifier Protection". I haven't looked inside that yet, but I suspect that I'll find a couple of power resistors in series with the inputs when I do.
The Leviton volume controls are just power resistors and a 12-position slide switch. I can see making a variable L-pad from those ingredients. The System Matching Module has no switches or jumpers; no moving parts at all; just a bunch of BIG ceramic power resistors on a circuit board. I can't begin to think how that can do impedance matching for an unknown number of the volume controls.
I can see how an autotransformer and a 12-position switch leading to taps in the winding can be a volume control. I've looked around for an explanation with a wiring diagram that shows how the jumpers change the wiring to multiply the impedance seen by the amplifier. Can somebody tell me where to look for that?
I said that I'd try to help this guy straighten out the mess. I'm not in that field, so I'm trying to learn about how all these things work. Inquiring minds and all that. Now I've just realized that I have two separate things going on in my mind here: one for him and one for me. For him I'd take the Sonos somewhere else, hook it to some decent speakers, and replace it with a streaming receiver and a six-channel amp that I've seen for sale used. $200 or thereabouts.
For me, I've gotten interested in how these things work; what do the jumpers do? And how does that reflect a different load back to the amplifier?
Thanks for reading, and just for the record, I wouldn't mind having a Model A, but I hear they're not cheap..
the.doc
Joined Jan 22, 2021
15
Solved! I got hold of one of these things, put an ohmmeter to it and found the solution: taps on the "input side" of the coil. I did suss out the connections, but I didn't try to measure the turns ratios, and the diagram is not to scale.
the.doc
Joined Jan 22, 2021
15
The amps all specify a minimum speaker impedance, usually 4 ohms. When you start hooking speakers up in parallel, you get below that in a hurry. That's the reason for the jumpers/switches on the in-room volume controls for x4 and x8 impedance multiplication.
Multi-channel amps seem to be the best solution. Worst case is four 8-ohm speakers in a room, which is a 2-ohm load. Use the x2 or x4 jumper setting, and it's good.
Ian0
Joined Aug 7, 2020
13,317
If you have four speakers then you can wire two series pairs in parallel and get back to 8Ω.
Audioguru again
Joined Oct 21, 2019
6,826
I think that modern speakers produce the best hifi when their resonances are damped by the extremely low output impedance of a modern amplifier.
But speaker sounds in a whole house will not be the best hifi anyway due to room echoes. Use the series/parallel connections.
Ian0
Joined Aug 7, 2020
13,317
The trouble with that is that you lose the damping effect from the low output impedance of the amp. I am sure @Audioguru again can elaborate.
So it would seem, but this is two identical loudspeakers* in series. If you have a Thévenin source driving two identical RLC networks in series, won't the voltage at the junction of the two networks always be half the source voltage?
Imagine a bridge-tied load amplifier (which has a +/- supply) driving two RLC networks in series. The voltage at their junction will always be 0V, so if you connect a switch between that point and 0V it will have no effect. So the situation is identical to a single amplifier driving a single speaker.
*Assuming the TS is thinking of using identical loudspeakers.
the.doc
Joined Jan 22, 2021
15
What I found on line says that wiring speakers in series does not work well when the speakers have internal crossovers, and these do.
