Looking for small electric hand drill for PCB
shortbus
Joined Sep 30, 2009
10,049
OK, went into the shop after getting home from dentist. The chart in the top of the belt drive lid says it is running at 2420RPM at the highest speed.
cmartinez
Joined Jan 17, 2007
8,783
That sounds awfully low ... I'm not sure if the hole finish would be acceptable at those rpm ... but I'll give it a try anyway. 1/32" HSS bits are quite cheap compared to carbide. And yes, I'll buy Cleveland bits and nothing else.
Glad to hear you've still got some teeth left ... :D:p
shortbus
Joined Sep 30, 2009
10,049
Only until next Thursday. Getting the last 7 out. Something going on with my jaw bones, teeth just come loose and only gums holding them. These will need some oral surgery because I've put it off too long.
cmartinez
Joined Jan 17, 2007
8,783
:eek: ... ouch! ... I didn't know it was that bad, sorry about the bad joke :oops:
Anyway, I have a couple of friends that have gone through the same thing and they tell me that their lives have improved dramatically after that. The quality of dentures nowadays is way better than it used to be.
shortbus
Joined Sep 30, 2009
10,049
Have had full upper since 2014 and a partial lower since the same time. The worse thing is I only had a few fillings. No idea from doctor or dentist what is happening.
I don't understand that statement? Why is finish important? Though it is good for a drilled hole, it is just getting a lead through it and solder. I use a piece of MDF as a backup so no burr on the bottom either.
shortbus
Joined Sep 30, 2009
10,049
Thought you meant finish inside the hole. My stuff has been high amperage and lots of copper around the holes, but haven't seen any pull up of the copper.
