Looking for RELAY Recommendations
Peter Mpashi
Joined Nov 9, 2023
7
I'm looking for a relay, 230VAC, that can work as follows:
Having a constant energizing signal, the normally open (NO) contact closes and then opens (like a push button) while the energizing signal is still on. The normally closed (NC) contact closes and then opens (like a push button) when the energizing signal goes off.
Something like what's shown in the sketch attached, where S is the signal, NO is the "Normally Open" contact and NC is the "Normally Closed" contact.
Your recommendations will be highly appreciated. (Any brand)
sghioto
Joined Dec 31, 2017
8,745
I don't think there is a single mechanical relay that can do that. I see a possible solution using two relays and some control circuitry.
Is the energizing signal also 230vac? What do the relay contacts control, how much current is involved?
Peter Mpashi
Joined Nov 9, 2023
7
Yes the energizing signal is 230VAC. The current involved is not more than 5 Amps. The contacts are controlling the starting and stopping of a motor. I'm only given access to three wires: A common, a starting line (starts the motor when it makes contact with the common) and stopping line (stops the motor when it makes contact with the common). The three wires were on a non-holding, three position rotary switch. I'm supposed to get rid of the rotary switch and let my controller do the switching.
Peter Mpashi
Joined Nov 9, 2023
7
OK. How does your "controller" going to fit into this.
The 24VDC is from a converter parallel to the supply of my controller. If I can have a DC device that can do the kind of switching I want, I can feed it the DC through an AC relay (I have one free Normally Open contact on another relay that I have in circuit already)
sghioto
Joined Dec 31, 2017
8,745
Not sure if I understand that fully but presently and from you description of the rotary switch it appears the motor is manually started and stopped and the 230vac is connected constantly to the switch as in this image, correct?
sghioto
Joined Dec 31, 2017
8,745
OK good. Then you can use the 24 volts DC as the excitation voltage and supply voltage to operate two 24volt dc relays to start and stop the motor. How long will the excitation voltage be present on average between start and stop?
Peter Mpashi
Joined Nov 9, 2023
7
On average, about 10 minutes.
vu2nan
Joined Sep 11, 2014
357
Here's my version, using three relays and an electrolytic capacitor.
The start pulse is generated when relay K0 is energised and capacitor C1 gets charged through the coil of relay K1.
The stop pulse is generated when relay K0 is de-energised and capacitor C1 gets discharged through the coil of relay K2.
The pulse width is determined by the time constant RC (resistance of the relay coil and capacitance of the electrolytic capacitor).
The 'NO' contacts of K1 and K2 are used to start and stop the motor respectively.
Nandu.
