looking for contact solution with 0 or about 0 ohm
Ya’akov
Joined Jan 27, 2019
10,258
What do you mean by OV, OA? That you want to turn off the connection completely?
Your 0Ω requirement, that is for the closed switch?
If that is what you mean, you might want to look at low loss reed relays like the ones used in high end multimeters.
LAOADAM
Joined Nov 21, 2018
956
Thank you. I mean just contact two wires, no power on the wires.
18,119
How is the contact to be made, manually? Automatically by some actuator?
If there's zero current, then the ohms don't matter and philosophically speaking, the wires are already connected.
LAOADAM
Joined Nov 21, 2018
956
Sorry my unclean description.
The control side still use whatever V need. The contact side now have a little contact resistance about 0.8 Ohm . it's no good for my use.
ian field
Joined Oct 27, 2012
6,536
Most mechanical switches will have an on-resistance of only a few milliohms.
There can be a problem with contact tarnish and/or oxidation in very low current applications. This gets very evident with dodgy electronic ignitions for the old kettering points if they don't put enough "wetting" current through.
A lot of modern power MOSFETs have RDSon somewhere in the milli Ohm range, and that characteristic is more stable.
