Thank you. I mean just contact two wires, no power on the wires.What do you mean by OV, OA? That you want to turn off the connection completely?
Your 0Ω requirement, that is for the closed switch?
If that is what you mean, you might want to look at low loss reed relays like the ones used in high end multimeters.
How does it help to connect wires if there will be no current flow?Thank you. I mean just contact two wires, no power on the wires.
A SPST switch, perhaps?just be able to control the ON/OFF of two wires, 0 V, 0 A.
Sorry my unclean description.
The control side still use whatever V need. The contact side now have a little contact resistance about 0.8 Ohm . it's no good for my use.
Ha, good idea.This should do it...
There can be a problem with contact tarnish and/or oxidation in very low current applications. This gets very evident with dodgy electronic ignitions for the old kettering points if they don't put enough "wetting" current through.Most mechanical switches will have an on-resistance of only a few milliohms.
