Looking for best way to Blink/Flash dual LEDs at 3v
tapir11
Joined May 17, 2017
Hi All,
I've got a dummy burglar alarm box that I want to add dual flashing LEDs (probably blue). I'm just getting into electronics and I'm hoping this could be a good first project.
Requirements:
Flash x2 Blue LEDs alternately
Alternate flash every 2 seconds (or similar)
Powered by x2 AAA's = 3v (lithium as they will need to work at low temps and last well)
From some research i've found out:
555's = require more than 3v to operate
Possible solutions:
LM3909
LM393
2N2907
BC548B NPN TRANSISTORS
But I'm not really sure what would work best - any advice?
Many thanks in advance,
#12
Joined Nov 30, 2010
18,224
(probably blue)
Not likely. Blue LEDs require more than 3 volts. You're probably stuck at the red end of the visible spectrum.
That CMOS 555 is a good choice and you can use a capacitor in series with each LED to get a quick flash while the timer is taking its sweet time to get the 2 seconds clocked out.
38,952
If you really wanted blue LEDs you could use a small inductor flyback circuit to generate a voltage greater than the battery voltage, such as the Joule Thief Circuit.
These circuits can generally operate down to a very low battery voltage, using just about every last bit of the battery energy.
tapir11
Joined May 17, 2017
thanks so much for the replies,
R!f@@ - Thanks I was unaware there was a low power version of the 555
#12 - Thanks, Red LED is OK and fine for these experiments
crutschow = Joule thief - very intresting - taking a look.
I've been looking on ebay and found sellers who look to make blue blink units running at 3v
http://www.ebay.co.uk/itm/BATTERY-POWERED-DUAL-FLASHING-BLUE-LED/141187128847
I'm temped to buy one to take apart to learn - there looks to be very limited number of components?
#12
Joined Nov 30, 2010
18,224
I ran a Joule Thief to its limit. It will start up if you have at least 0.6 volts and it will suck a battery down to 0.3 volts if it's already running.
A joule Thief isn't any more complicated than a crystal radio but it uses a magnetic coupling which is about 9th on the list of what beginners might get around to studying.
