Looking for a SSR to trigger a signal
MichiganWolverine5974
Joined May 13, 2015
68
I am looking to use a SSR to trigger an output signal to a 24v light. The signal is coming from a PC. It is a 5v digital output signal and that signal has a current drive of +/- 5mA. Most SSRs I could find require at least 15mA. Is there a SSR out there that will work for this application? Below is the link to one I was looking at, but it looks like it requires a 15mA current drive. TIA for your help!
https://www.mouser.com/ProductDetai...=sGAEpiMZZMtq49AUx5G37/Kb9mP7Eth6PajLcLdw38s=
ericgibbs
Joined Jan 29, 2010
21,479
hi M597,
What is the PC type.? 5mA seems a little low.
E
EDIT:
Looking at SSR datasheet it states the device can be triggered by a voltage as low as 3V.
So a simple transistor emitter follower could deliver the 15mA at 4.3v.
E
ian field
Joined Oct 27, 2012
6,536
https://www.mouser.com/ProductDetail/Crydom/DRA4-MCX240D5?qs=sGAEpiMZZMtq49AUx5G37/Kb9mP7Eth6PajLcLdw38s=
5V input SSRs aren't hard to find - most mains types are triac output, so will only work if your lamp is using AC.
There are DIL 8 optos for telecoms applications with inverse series pair MOSFET output. they can handle a fair but of current, but I can't remember how much.
an SSR is pretty much opto-zilla.
Joined May 13, 2015
68
hi M597,
E
EDIT:
E
It is a digital out 5v signal from a national instruments software card. I'd ideally like to tie the digital 5v signal directly into the relay without any other circuit or power supplies. Then just have the relay switch between two lights dependent if the signal is 5v or 0v. But again, I am just worried there isn't enough current output from the NI card to activate the SSR/Relay/Opto.
LesJones
Joined Jan 8, 2017
4,509
You could use an opto isolator and amplify the signal on the output side The design would depend on weather the 24 volts was AC or DC. (Which you have not told us which it is. Also you have not specified the lamp current.)
ebeowulf17
Joined Aug 12, 2014
3,307
Joined May 13, 2015
68
Sorry for not being completely detailed. So the lights are being controlled by a 24vdc power supply. I am not worried about the output side, as the lights will power dependent on whether the relay is NO or NC. I am just concerned with the signal into the relay or SSR I want to use. I hope this clears it up.
Thank you again everyone for all your help. I hope you all enjoy your weekend!
ebeowulf17
Joined Aug 12, 2014
3,307
Still not following clearly on your load requirements. Are you saying that the current for the lights won't be running through the SSR you seek? Is it that the SSR is just switching a signal level control which tells the lighting power supply whether or not to be active?
The amount of current to be run through the load side of the SSR matters. We can't recommend an SSR without knowing it (or at least a ballpark range.)
Reloadron
Joined Jan 15, 2015
7,893
Would there be any reason you can't just use a MOSFET? Using a Logic Level MOSFET you can drive a relay or for that matter the lights themselves.
Ron
