Looking for a large current adjustable circuit
LAOADAM
Joined Nov 21, 2018
956
I am looking for a large current adjustable circuit, 48V at about 200A, no matter what components used.
Need help please.
Thanks
Adam
22,095
Need help please.
Thanks
Adam
I'm not sure what that is. Can you elaborate on the phrase "current adjustable circuit"? Are you looking for a variable load that can dissipate up to 10 kW? If so good luck. If you are going to dissipate that amount of power I don't want to be responsible for your electric bill and you may as well do something useful like run motors. Maybe you just want to be the first kid on your block to make the lights go dim. A good radial arm saw will do that for you. Better yet a whole bank of them and switch them on in sequence.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
I have two 24V SLA batteries, and I try to use them series connection for testing Resistance heaters. I like the station be able to test different value of resistance at as less as the V charges.
sparky 1
Joined Nov 3, 2018
1,218
The batteries CCA will change. In order to test you need to record %CCA
A meter like foxwell could measure 24V battery. With new batteries the %CCA does not present problem at first.
When you charge the batteries and keep getting low % cold cranking amps your seal lead acids will limit your ability.
With a data logger the chart reveals voltage drop on your resistive load along with the test ID and %CCA and temperature. The file from the data logger uploads to a spreadsheet. Because you have different loads that would be an AC equivalent of this using PWM with large heatsinks the spreadsheet would give the DC equivalent.
Last year my new battery's percentage CCA dropped an average of 5% each month. In 9 months it would retain only 45% CCA
Dependability, service life, return date are far less than years past while the cost have sharply increased.
LAOADAM
Joined Nov 21, 2018
956
Thanks for good advice.
My testing is simple, just record the relation chart between: I/V/T/t (Current/Voltage/Temperature/time).
LAOADAM
Joined Nov 21, 2018
956
What are the test specifications ?
What exactly are you trying to find out about the Heaters you are testing ?
All of the small details are very important.
Thanks.
I don't have much detail yet, just in Preparation Phase。
LowQCab
Joined Nov 6, 2012
5,101
Specifically, how much Time do you think will be necessary to obtain the required Temperature ?
This can be calculated, and extrapolated, once the initial start-up behavior is established.
The start-up behavior can also be an indicator of Life-Expectancy.
If the Heating-Element is not attached to its normal Heat-Sink, the results may not be 100% valid.
You also need to take into consideration whether the Batteries can repeatedly withstand the abuse.
I believe I know what you want, and have almost finished the design,
but I want to make sure of what you expect to happen, especially the Duty-Cycle.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
1. the Testing Time Cycle need be set after a Tentative test;
2. the Heating-Element will be tested with and without Heat-Sink.
3. the battery group may not be a good choose, especially the test need be conducted time by time.
LowQCab
Joined Nov 6, 2012
5,101
OK, lets try again, how about a general, roundabout, sorta-kinda, amount of time ?
0.5-Seconds ?
1-Second ?
10-Seconds ?
30-Seconds ?
5-minutes ?
30-minutes ?
And, at approximately what variable Voltage and Current ?
LAOADAM
Joined Nov 21, 2018
956
0.5-Seconds ?
1-Second ?
10-Seconds ?
30-Seconds ?
5-minutes ?
30-minutes ?
Thanks.
I'll put these in my design plan after I collect as much information as I can.
