Logisim exercise
ValentinNiculae
Joined Dec 1, 2022
Hi all,
Can anyone help me with the below exercise ?
I have to "Build a circuit that has two 8-bit two’s complement numbers U and
W as its inputs and a single 1-bit output R, which is 1 when W − U is
negative and 0 otherwise." In logisim
Thank you
WBahn
Joined Mar 31, 2012
32,805
This is what I have done so far 8-bit incrementer subcircuit, 8-bit subcircuit adder, 8 subcircuit bit mux , the problem is if W-U is negative output should be 1 or otherwise 0 I cant think of anything elce to solve this please see attacher logisim file
How can you subtract one two's complement number from another number using an adder?
KAlex610
Joined Apr 9, 2023
6
Did you solve it ??
