Logisim circuit design
kindjupiter
Joined Oct 24, 2016
Hi there, I have to implement a project which is pong playing on logisim and then to play on a fpga board.Honestly I dont have any idea how and from where shall i begin? I really appreciate if somebody can help me and write me back.
Merci
Kind jupiter
WBahn
Joined Mar 31, 2012
33,257
If you REALLY have no idea how to begin, then you probably need to go back and retake the prerequisite courses for the course you are currently in. Then, when you retake this course, you might be in a better position to learn the things that you were expected to learn that are needed for a project like this.
Otherwise, you might try breaking the problem down into tiny little steps and walk your way from a very simple start (being able to make the entire screen either white or black) to the fully functional game.
kindjupiter
Joined Oct 24, 2016
merci WBahn
for your reponse.I started to chob it in smaller steps,first i define the random generator with a spliter connected to 7LED which plays the role of ball circulating on a field with X=12 and Y=10 dimension.
Do you know how i can define the field which connected to random generator which move in field.
