I need to build the logical circuit using PSIM, do you know how to build it?Separate the conditions for each output signal and then simplify the expressions to get expressions for each output signal. I assume you need expressions for behavioral voltage sources and that U is a voltage signal at node U. Logical expressions produce outputs of 1 (true) or 0 (false).
| Thread starter | Similar threads | Forum | Replies | Date |
Issue with 2-Digit BCD Adder-Subtractor Circuit Using 74LS83 | General Electronics Chat | 1 | |
Logic Design | Jobs & Career Advising | 5 | |
Transistor logical AND circuit | Power Electronics | 50 | |
Digital Logic Design Questions | Homework Help | 4 | |
| M | Design a synchronous counter flip flop | Homework Help | 2 |
