Logic Optocoupler for 8 Channel - Possible?
Mizs Faa
Joined Nov 25, 2015
11
Hi, im doing my current project which is i have to connect with solenoid valve to arduino using N-channel Mosfet.
The problem is i need to use LOGIC OPTOCOUPLER for my circuit connection as precaution.
So im gonna use 8 solenoid valve which is IF im using single channel of optocoupler, i need to use 8 of optocoupler in my circuit.
The problem was the 8 channel of logic optocouple is possible? because im searching for it through website unfortunately i didnt found. Im only found 2channel of optocoupler (Logic).
http://docs-asia.electrocomponents.com/webdocs/0779/0900766b8077970f.pdf
That nice if you can share some link of 8 channel LOGIC optocoupler or maybe 4channel of LOGIC optocoupler.
Best Regards,
Faa
