logic of V23105A5003A201 relays
yef smith
Joined Aug 2, 2020
1,486
relay is a switch :) switch as I see it is a button I press to turn it on.
What could be the functionality of this component in this case?
Thanks.
38,936
A relay is a switch that can be controlled by an external signal.
The signal goes through a coil, generating a magnetic field which closes the relay contacts.
The signal could be from a (remote) switch, or an electronic circuit such as a microprocessor.
eetech00
Joined Jun 8, 2013
4,746
Hello, i am using the device below in the circuit.
Is supposed be lik a switch which closes when magnetic field in ON.
However as you can see in the photo of the circuit i dont see why i need to detect magnetic field.
What is the logic of putting such device?
Thanks.
https://eu.mouser.com/ProductDetail/TE-Connectivity-PB/V23105A5003A201?qs=Nk6ydC/JI6yMODpxTMiS9Q==&utm_id=20109199406&gad_source=1&gclid=CjwKCAjwupGyBhBBEiwA0UcqaB8MpXTnuxW8KjycviVocQlMVoEF5fFlVMbdGT2eoO6-iaxpSem7GhoC3F0QAvD_BwE&_gl=1*1lgbyoa*_ga*NTg5OTk0NTQuMTcxMTI4Njk2Nw..*_ga_15W4STQT4T*MTcxNTc3MDA1MC4yLjAuMTcxNTc3MDA1MS41OS4wLjA.
That is an ordinary miniature 12v relay, not a reed relay.
Reloadron
Joined Jan 15, 2015
7,977
This is the relay you point out in your initial post.
It's a relay, that's all it is. Apply a voltage to its coil and it energizes.
Your link is Understanding Reed Switches and Reed Relays. You point out the latter, a reed relay. A reed switch requires a magnetic field to open or close, a reed relay has the magnetic field of its coil to energize. These are two different parts used for different applications. Both are a switch but both are closed differently.
Ron
28,538
In the one photo I see one device that clearly is a reed relay. I see a partial photo of what is probably the device in question, which does not mention a coil voltage. But with a poor picture that does not show the complete label we can only guess.
THAT DEVICE may actually be a dual reed switch, which to the unknowing looks exactly like a reed relay, except for no coil connections. THE REASON for putting reed switches in a package like that id because reed switches break easily and they are difficult to position exactly.
So post a picture that includes ALL of the marking on the other device and we can provide an answer.
