Logic Gates-NOT Gate
Michael Gehen
Joined Jun 26, 2011
Under the Education Section, Logic Gates-->NOT Gates. There is a diagram of the internal structure of a NOT gate under the paragraph "Low Input Output Analysis". This is the very first diagram under this paragraph. Should not the input side (switch) be attached to ground not the Vcc power supply?
eetech00
Joined Jun 8, 2013
4,728
Yes, the input switch position shown is incorrect.
The input switch should be shown in the "down" or "ground" position (or some movement to the ground position) for the circuit description to make sense.
