Logic design for a 7483 4 bit adder ic
Saliba Majdalany
Joined Jan 17, 2021
9
Use the 7483 4-bit adder IC to simulate a circuit in which two four-bit binary numbers are added A+B where A has a decimal value of 2 and B is specified by the user. Display the result of the summation of A and B on a 7-segment display. Let the decimal point of the 7-segment display be the indicator of the carry bit result.
Simulate your circuit using integrated circuits (ICs), switches (logic 1 when switch is closed) and LEDs (logic 1 when on).
(upload the simulation file)
ericgibbs
Joined Jan 29, 2010
21,593
hi,
As this is Homework please post your best attempt at answering the question, we can then help you.
Which simulator do you use.?
E
