logarithmic variable capacitor for tuning?
Hamlet
Joined Jun 10, 2015
560
I'm contemplating experimenting with radio receivers. To my understanding, when tuning, the variable capacitor often squashes the upper bands, tuning gets fiddly, as smaller and smaller increments of rotation of the variable-cap have large changes in freq. selection (or maybe I have it the wrong way around)?
Anyway, my question(s) is, would it be advantageous to construct a tuner with the variable-capacitor having logarithmic characteristics? And if so, where should the capacitance have the greatest change when moving up in freq., at the bottom or top of the dial?
This log-cap seems to suggest by it's construction that
it capacitance increases significantly as it is rotated
clockwise.
Hamlet
Joined Jun 10, 2015
560
Bottom of the dial as illustrated in the photograph you posted.
Thanks Dick, I think you answered my question, but I'm still confused.
Generally, do we want lots of capacitance at lower
freq., with wide swings of cap. at small rotations, & then, with the high end of the dial
experiencing tiny amounts of capacitance, with small changes for larger
rotations of the dial?
(Presuming we want an intuitive tuning, a clockwise rotation would have decreasing
capacitance. It seems the picture I provided would need gearing to correct, as natively,
it appears to be anti-log in function.)
Ya’akov
Joined Jan 27, 2019
10,300
The intuitive quality of the direction will depend on whether you tune by wavelength or frequency.
28,318
The reason is explained by the formula for the resonant frequency, and by the fact that as the capacitance is reduced, a change of any fixed increment becomes a larger part of the whole capacitance.
AND, for any given frequency tuned to, a fixed increment change in frequency becomes a larger portion of the actual frequency.
Hamlet
Joined Jun 10, 2015
560
I don't have many large variable caps on hand, so I had a go at making
a multi-leaf style variable-cap that uses a screw-press arrangement with threaded
rod to increase capacitance. The ratio came out good (35:1), and logarithmic, but I anticipate
fussy operation because of the short range of motion, and right-hand threaded
rod will make for a counter-intuitive anti-log tuning.
28,318
Use a string and pulley arrangement like tuning some older radios and reverse the rotation that way. Cheap but complicated. OR use a gear drive. A couple of gears from a failed mechanical clock.
Hamlet
Joined Jun 10, 2015
560
I remember the days when those things were ubiquitous.
They have gone the way of the dinosaurs.
Yes, meccano gears are expensive on ebay, a collector's item it seems,
and so are variable capacitors.
I'm boiling up some pcbs to make guillotine style variable cap. right now.
If that isn't suitable, a trombone variable is in the cards.
sparky 1
Joined Nov 3, 2018
1,218
basic radio builder open 15pF in the low and medium bands like the picture or 350pF when the log shaped fins are
closed. Below 15pF the hand capacitance gets touchy. Example I want Xl=XC with a reactance of 1000 ohms 50pF 50uH 3.18 MHz
If I adjust to 15pF gives 5.8 MHz the reactance now 1825 ohms at 75% 260 pF 1.4 MHz reactance 438 ohms
The reactance is up to you. A combination of weak signal and accurate tuning giving up bandwidth for better selectivity.
I like to start design at 50pF but it might end up at 25pF and that is your high range while the more accurate tuning at 350pF a station of interest might be at 75% its cheaper to make round plate capacitors but logs are nice
Ya’akov
Joined Jan 27, 2019
10,300
Isolation couplings are certainly helpful, and very much required when both sides of the capacitor are at some high voltage level. So thanks for the reminder. That is quite the collection!
Not mine, unfortunately. I did have quite a box of tuning caps and couplers but they… are gone. Years of apartment living and many moves took a toll on the boxes of stuff I couldn’t ”justify”.
Ya’akov
Joined Jan 27, 2019
10,300
Try the Meccano website, the guy that answers is from Borgfeldt and the gears cost a buck or two depending on size. Also RC gears come useful at times. Otherwise SDP/SI also has gears. There is another good place but their name evades me for the moment, maybe someone can chip in.
W.M. Berg is one of my favorite sources but I wouldn't class them as "cheap". I used to buy a lot of components from them when I was building science museum exhibits.
Hamlet
Joined Jun 10, 2015
560
I stand corrected. I hadn't realized that Meccano was still a going concern. A really well engineered toy. The UK has an impressive engineering legacy. Meccano's presence in the USA has been somewhat limited. I don't recall a single lad growing up that had one; I would have remembered that!
