log Base 10
SamR
Joined Mar 19, 2019
5,513
It's been a while since I've used logarithms but doesn't the unannotated term log imply base 10? So that when using base 2 or base e then it would need to annotated as such?
xox
Joined Sep 8, 2017
936
From a "pure" mathematical perspective, "log" means the natural logarithm. In the sciences (and elsewhere), log is instead used to mean the base ten logarithm, although certainly not always. Boltzmann's entropy formula for example uses it in the former sense. Earthquakes, on the other hand, are measured on a log10 scale, and yet sometimes referred to in various literature as simply being "logarithmic". So it really just depends on the context where it appears.
38,615
Whether it's measured in base 10 or base e, makes no difference to the designation as being "logarithmic".
WBahn
Joined Mar 31, 2012
33,027
Depends on the context, so it's safest to use a subscript with the log function and to check, when possible, what base the log is being taken to. Most programming languages use log() for the natural log and log10() for the common log.
SamR
Joined Mar 19, 2019
5,513
K, thanks guys! Decades ago when using my slide rule, it was log or ln. Or at least that is sorta how I remember it. Not a bad suggestion to subscript it to remove any ambiguity.
MrSalts
Joined Apr 2, 2020
2,767
Best way to know is to try it.
If you ask someone, you'll get many opinions and still not know.
SamR
Joined Mar 19, 2019
5,513
Using MS Mathematics and my various TI calculators. Actually seems like my TI-36 PRO works the best for logs except I am unable to set the base on any of them it seems. The 36 has a quirk in that it somehow cannot solve the square root of 3? The 83 you have to scroll through a catalog to find the log function so it is a PIA. The nspire is a poor substitute for a computer so I use my computer with MS Math instead. Haven't read the help file for MS Math to see what all it can do with log.
Edit: Yep, for MS Math log(x) is base 10 but for log(b,x) b is the base so that's good news.
MrSalts
Joined Apr 2, 2020
2,767
MSExcel also works well.
The NSpire also has a TI-84 faceplate that can turn it into a TI-84 (or maybe that was a special edition Nspire. But the TI-84 is a great calculator (for me).
SamR
Joined Mar 19, 2019
5,513
Nope, I misspoke. It is the Nspire that you have to dig through their catalog to find the Log function. The 83 has log and ln on the top keys so you don't even have to shift to get to them. And it does know how to do square root of 3 unlike their 36! But the 36 doesn't use batteries and works in low light conditions plus a bit smaller and a lot less heavy.
Edit: Did a bit more digging on the Nspire. Log is NOT covered in the TI guidebook but I found out that it is easy to get to the log functions and it DOES support bases. Might actually be easier than using MS Math.
WBahn
Joined Mar 31, 2012
33,027
Slide rules were set up with base-10 in mind because they were tools to facilitate doing base-10 arithmetic.
Most scientific calculators have as their primary audience high school and college students. Most high school students (historically, at least) get introduced to logs right after they learn about exponents and radicals with the application being as a means of doing multiplication and division using addition and subtraction, so they are learning it in the context of base-10 operations, likely two or three years before they ever get to the point of learning about the existence of natural logs (which are often introduced when they are learning integral calculus).
Consequently, it is natural (no pun intended) for them to think of log() as being the base-10 logarithm and the calculators that they buy sell better if the notation on them is in line with this.
This is one of any number of examples that shows that the professional side of a field (working mathematicians, for whom log() means natural log by default) and the educational side (where log() means the common log by default) are different critters that are not always in sync.
38,615
My old HP42s will also do the square-root of -3 (or any negative number) as it can handle complex numbers.
It uses LOG for base 10 and LN for base e logarithms.
(The picture is from my virtual 42s on my laptop.)
SamR
Joined Mar 19, 2019
5,513
Once I figured out how to use the Nspire, if I don't enter a base number in the subscript space, it assumes base 10 and fills in the subscript as 10 automatically. In an older text I was perusing today it mentioned using lg for base ten instead of log. Maybe it's old age but I don't remember anything about a base other than 10 or e. Once I got the hang of using base numbers and the theory behind it, it's not so bad and makes a lot of sense. So I'm surprised I don't remember ever seeing it before. It makes it pretty easy to convert from log to exponential expressions.
Also discovered that the Nspire won't resolve the square root of 2. Very strange, the 36 won't do 3 and the Nspire won't do 2?
WBahn
Joined Mar 31, 2012
33,027
In several fields, lg() is used to indicate the base-2 logarithm. But this just underscores that it is unsafe to make assumptions about what base is being meant (except that ln() is all-but-guaranteed to mean natural log) -- different people in different fields mean different things. So, when YOU write something or document something, be explicit. If nothing else, put a note somewhere that indicated what your nomenclature is.
I can pretty much guarantee that those calculators will have not a problem calculating the square root of either 2 or 3. Either you are doing something wrong, which is by far the most likely explanation, or your particular calculators have something wrong with them. It's possible, but unlikely, that two calculators have a similar problem. Review the documentation to see if you are overlooking something subtle. If not, then you might put in new batteries (if it uses them).
SamR
Joined Mar 19, 2019
5,513
Batteries are not the problem. Found out entirely by accident during a calculation. In both cases it shows the root symbol with the number under it and when enter is pushed it moves from the left-hand entry side of the screen to the right-side solution side. The older TI-83 has no problem with either. I've done a lot of root calculations over the years but nothing simple like finding the root of 2 or 3 until I started doing the exponential equivalents of some Log to different roots expressions. If I multiply or divide it, it remains as a symbol. But if multiply 2 of them against each other it solves or if I raise the square root symbol to any power it solves. Nothing that I've read in their literature about it.
Also the 36 does do 3^1/2 so it can express the square root of 3. Such a weird "feature"...
bogosort
Joined Sep 24, 2011
696
I have a Ti-36X Pro, which does the same thing. The calculator defaults to showing you the exact answer (if possible) when pressing the 'enter' key, which can be handy (e.g., typing \(\sqrt{18}\) and pressing 'enter' will result in \(3 \sqrt{2}\), and typing \(\frac{17}{51}\) results in \(\frac{1}{3}\)), though this isn't always desired, as you've found. Press the '\(\approx\)' key above the 'enter' key to get the approximate decimal representation.
Strangely, the situation is reversed when using the built-in functions: typing \(\sin^{-1}(1)\) and pressing 'enter' gives you 1.570796...; pressing \(\approx\) gives you the exact result \(\frac{\pi}{2}\).
SamR
Joined Mar 19, 2019
5,513
Thx Bogo. Yes, I have since discovered that the TI calcs differentiate between exact and approximate (repeating decimal and such as Pi) results accordingly. Should have updated the thread but it was old and getting stale when I found out what the calculator was actually doing.
