Load Resistance and Max Power
gengm
Joined Apr 7, 2010
23
Here is the problem
I know the open circuit voltage, and the current and resistor on the other side of the terminal pair, but how do I go finding the load resistance?
bertus
Joined Apr 5, 2008
23,000
What is the voltage drop ofer the 8 Ohm resistor?
What is the difference between open and 8 Ohm load?
How many resistance is needed to drop this difference at 20A?
Jony130
Joined Feb 17, 2009
5,599
The "black cox" contains a ideal voltage (Vth) connect in seres with Rth resistor.
If R_load = ∞ then Vo = Vth
And now if we connect R_load = 8Ω
Vo = 8Ω * 20A = 160V so 20V is now drop on a Rth resistance.
