load lead vs hot lead on timer switch
rwstern1
Joined Oct 19, 2015
5
I bought an in wall timer switch to control outside lights. The switch has a ground, a common, a hot and a load lead. My standard wall switch has only the black (hot) and white (common) wires. Can this timer switch be used on this circuit?
MikeML
5,444
If you put in a country location when you registered, we wouldn't have to play twenty questions!
Is the box that it is going into metallic or plastic?
Is there a green wire in the box?
30,808
Are the outside lights low voltage?
If so it maybe the type that typically has a isolated supply and in that case low voltage can be ran without ground.
If mains powered then you should have a service ground that leaves the timer.
rwstern1
Joined Oct 19, 2015
5
It is a plastic box. No green wire, just the bare ground wire. It is installked in Florida, USA.
mcgyvr
Joined Oct 15, 2009
5,394
part number of timer?
Did you try reading the manual?
The only thing unclear is the function of the "load line" in the timer..
Which might be for devices that are downstream of the switch that you don't want on the timer or vice-versa.. Manual should call it out or have a diagram..
rwstern1
Joined Oct 19, 2015
5
Utilitech, PN 0141224. Nothing in instructions. Notrhing downstream of the lights being switched.
MikeML
5,444
Box-blk is power into the timer. The blk wire? that goes outside to the lights goes to the load terminal on the timer..
Box-wht is neutral, goes to com side of the timer and to the wht. wire to the outside lights.
Box-bare is ground, goes to gnd terminal on the timer and to the outside lights.
30,808
If you have no ground wire to feed the outside lights, or they are not fitted with a ground conductor, use a GFI socket for the timer.
rwstern1
Joined Oct 19, 2015
5
Thanks.
