Hi there,
When replacing turn signal bulbs (12v 27w) with Led, you will experience the notorious hyper flash issue. Hyper flash is when the turn signal light flashes rapidly.
The easy way to solve the hyper flash, is to install a load resistor (6 Ohm 50w resistor). This solution will make the resistor very hot, and can be dangerous in tight spaces like a motorcycle.
Another way is to use an electronic circuit to create this load without heat , and I am looking for that , does someone have a lead on how to achieve this ?
Thanks !
Thanks !
