LM7805 question
28,331
Would suggest a different approach; a Buck Converter.
The 7805 has to waste 8.8 volts whereas a buck converter will switch on and off rapidly. Depending on the desired output you adjust it down. In the end the buck will be OFF more than it is ON. This results in an average temperature. A rough estimate of percentage of ON time is approximately 40%. It will run a whole lot cooler too.
I definitely agree that a buck converter will be a much more efficient choice. You will need to add a filter capacitor, though.Many years ago I did try adding a series resistor with a 7812 regulator dropping from 24 volts. The result was a 15 volts peak to peak oscillation on the 12 volts line. I had to add both a 20 FD capacitor to the input PLUS the 0.1 MFD on both input and output, to halt the oscillation.
MaxHeadRoom
Joined Jul 18, 2013
30,813
I have been using the TO92 and the TO220 versions for some years now and never ran into a problem, observing the manuf. design criteria. ! :confused:
Ian0
Joined Aug 7, 2020
13,281
I like the series resistor - it has other benefits apart from reducing the power dissipation in the regulator. With a good big capacitor on the input it reduces the input ripple, removes high frequency noise (a 7805's PSRR isn't great) and removes short-duration spikes on the power supply. I put a TVS diode across the capacitor for good measure.
