LM7805 question
PickyBiker
Joined Aug 18, 2015
144
I have a microcomputer circuit that runs on 5v. I am using an LM7805 to bring the 13.8 battery power down to 5v and the 13.8 v draw is .34 amps. The LM7805 is getting very hot. The spec says it can output 1.5Amps so why is it getting hot with only 1/3 of an amp?
Ian0
Joined Aug 7, 2020
13,279
How big is the heatsink?
Work out how much power it dissipates (Input Voltage - Output Voltage) * Current.
PickyBiker
Joined Aug 18, 2015
144
It doesn't have a heatsink.
13.8v - 5v = 8.8v
8.8v * .34A = 2.992 W
It has a 10uf cap on the output.
3 watts doesn't seem like a lot of power to dissipate, but it is getting hot. So, I guess the question is, how big a heatsink is needed to dissipate 3 watts?
dl324
Joined Mar 30, 2015
18,471
How hot is hot?
The regulator has built-in thermal protection. An inexpensive heatsink would increase lifespan.
This one will limit junction temperature to about 100C:
It still won't be comfortable to touch the case.
PickyBiker
Joined Aug 18, 2015
144
I don't have a way to measure the temperature, but it burns my finger, so I will buy one of the heatsinks you posted.
Thank you, Dennis.
Ian0
Joined Aug 7, 2020
13,279
Thank you, Dennis.
If you can just keep your finger on it, it's 50°C. If you have to let go it's 60°C. If you lick your finger and it sizzles when you touch the device, it's 100°C.
Note: Don't try it with triacs.
38,827
A TO-220 package has a thermal resistor to air of about 70°C per watt, so with a typical ambient of 25°C and 3W dissipation, the case temperature would be 235°C, well above its maximum rated operating temperature.
ThePanMan
Joined Mar 13, 2020
950
Would suggest a different approach; a Buck Converter.
The 7805 has to waste 8.8 volts whereas a buck converter will switch on and off rapidly. Depending on the desired output you adjust it down. In the end the buck will be OFF more than it is ON. This results in an average temperature. A rough estimate of percentage of ON time is approximately 40%. It will run a whole lot cooler too.
Papabravo
Joined Feb 24, 2006
22,111
You could also split the power dissipation between two devices by using a pre-regulator. This might not be practical for a one-off project, but it was quite successful in an industrial application. The pre-regulator would consist of a power transistor, Zener diode, and a resistor. Suppose the pre-regulator put out 8V to accommodate the typical dropout voltage of a 7805 and it consumed the same 340 mA. Then:
\( (13.8\text { V}-8\text{ V})\times0.34\text{ A}\;=\;1.97\text{ watts} \)
Follow that with the 7805 regulator which has the following characteristics:
\( (8\text{ V}-5\text{ V})\times 0.34 \text{ A}\;=\;1.02\text{ watts} \)
We have not eliminated ANY power dissipation; we have ONLY divided it between two devices. This would allow you to choose an alternate package for the power transistor which might have superior dissipation characteristics e.g. a TO-3 package while keeping the TO-220 package for the 7805. This solution may not be appropriate in all cases, but it is a possible way to go.
Ian0
Joined Aug 7, 2020
13,279
My favourite easy-to-use regulator at the moment is the LMR38010. It takes any input up to 80V, only needs 7 external components and just works - provided that you don't forget the decoupling capacitor on the input.
Jon Chandler
Joined Jun 12, 2008
1,645
Nobody has mentioned....if you can supply a lower voltage, the power dissipation will be less.
A 4 watt incandescent night light bulb will burn your finger.....
MaxHeadRoom
Joined Jul 18, 2013
30,813
I am using TO92 78L05 with a 9 pin micro and 12vdc in put with no problem. It can take up to 30v max DC.
Ensure the 7805 has the 100nF at input AND at output otherwise it oscillates and overheats.
MaxHeadRoom
Joined Jul 18, 2013
30,813
13.8v - 5v = 8.8v
You didn;t confirm yet if it has the mandatory 100nf on the input & output?
