LM35 connected to op-amp
aab09
Joined Dec 12, 2014
3
Hi
I need your help. My project is to design sensor that connected to op-amp.
temperature range from 35°C – 45°C, and ADC range 0 – 3.3V.
aab09
Joined Dec 12, 2014
3
I asked the doctor about it he tell me to get output voltage of opamp=0 when T=35, output voltage of opamp=3.3 when T=45
MikeML
5,444
We, instead just giving you the answer, in which case you learn nothing, are waiting for you to show some initiative and suggest a solution...
btw- I am a retired doctor (PhD). If you were my student, I would fail you if I learned that you just copied a solution that someone handed to you.
ScottWang
Joined Aug 23, 2012
7,501
So now you should figure out how a op amp to do the amplifying as inverting and non-inverting, and then draw the circuit and attach it here.
Wendy
Joined Mar 24, 2008
23,797
You will note that everyone assumes this is home work, which means it gets treated differently. Make a serious attempt to solve the problem, draw a schematic you think might work, and you will go further. The more input you give the more hints toward solutions you will get, and the more you will learn.
