In my project, I want to achieve relays to be on and off at different reference voltage levels when an analog voltage signal input from 0.0V to + 2.0V is applied to the inputs of LM324 IC. When the inputs returns back to levels less than the ref voltages, the related relay comes to off state again.
Please see attached diagram which is a part of a LM324 Opamp circuit.
My question is: When input voltage reaches the reference voltage, relay works with chattering and this contiues if the input voltage stays same as the ref voltage, which may really happen in real life, but, when it goes beyond above the ref voltage chattering stops any way. This could be a hysterisis problem. I want to avoid this chattering problem.
How I can solve this problem. Please, somebody can help me.
Regards, good fellows.
Cevval of yours.
Cevval of yours.
