Ok I have made my argument and Texas Instruments have also made my argument for me. You keep telling us I am wrong and yet we don't seem to be getting any reason why, only your own certainly that you cannot be wrong.Claim what you want, the reality will always be reality.
Read the app note please guysHello,
Think of what would happen to the LM317 when you put in 60 Volts and have a short on the output.
The regulator will blow in that case, as the Vin-Vout difference is more than the allowed maximum.
So basically you have just your word, yet again, I shouldn't be surprised really. Pick and choose whatever facts you feel you need to support your denial.Well, here is basically how the pre-regulator (which happens to be a tracking regulator as well) work in the NatSemi app note, simplified here for ease of understanding.
The pre-regulator here is a mosfet, and the 3-terminal regulator is an LT 5v regulator. The zener used is a 10v type.
Because the zener is referenced to the output, the pre-regulator's gate sits at Vout + Vznr = 15v here, as confirmed by the simulation with the red trace, V(n002).
With Vgs = 1v, the 3-terminal regulator's input voltage stays at Vin = 14v (=Vout+Vznr-Vgs), regardless of how high the input voltage V1 is, once the regulator starts to kick in after 15v.
So the voltage across the 3-terminal regulator is Vin - Vout = (Vout+Vznr-Vgs) - Vout = Vznr - Vgs, again, regardless of how high the voltage source V1 is.
I have built this type of circuits countlessly, with linear pre-regulator or switching mode pre-regulator, with fixed output or variable output, with zener or leds as the regulating device, etc. Its beauty is in that constant voltage across the 3-terminal regulator.
So the fact that the combined circuit can take far higher voltage is no support for the notion that the 3-terminal regulator can take far higher input than specified in the datasheet.
Hope it helps.
It is very easy to test:
put your power supply to 160v and put a lm317 (or any other regulator) to it and see what happens.
Please make sure that you wear safety glasses and have fire extinguishers stand-by,
It is nuts that something like this needs to be discussed.
If a LM317 can take on 160v, do you think the app note linked earlier in the thread needs the pre-regulator?
And if you understand how that circuit works, you will know that the voltage drop over lm317 in that circuit is far lower than 160v, depending on that zener used.
All it takes here is common sense.
i got 3inch high, 4 inch wide and 1 inch thick (including fins ) heat sink on it . Heat sink takes heat like lava.You need heatsink on the regulator.
At this point, no body knows what circuit you are trying to build and which two points your voltage measurements are. It helps to put a schematic that shows where you are measuring and how you are measuring.It is outputting 34v actually
