LM317T Is there a minimum voltage inputtoget the required output voltage?
RodneyB
Joined Apr 28, 2012
697
Is there a Voltage drop when making a voltage regulator when using the LM317T.
I am trying to regulate the voltage onto a small load to 12 Volts. I have a battery with a voltage of 13.8 volts as the supply but the output never can be set at 12 Volts. I an trying to understand why
dl324
Joined Mar 30, 2015
16,918
How small of a load and what is the required voltage regulation?
21,225
Sorry I don't see where it shows on Page 4 the voltage
The load is 50mA. I would like to keep the voltage at 12 volts
On the fourth page, section 7.3, second line item, Vi - Vo Input-to-output differential voltage, MIN(imum) 3V, MAX(imum) 40V.
For 12V out you need at least 15V in.
30,058
Also, even with an LDO regulator, the 13.8 V source that you mention sounds suspiciously like a fully charged lead acid battery. That voltage will drop as the charge drops, so you will probably drop out the regulator before using very much of the battery charge.
dl324
Joined Mar 30, 2015
16,918
Unnecessary requirements will make for an unnecessarily complex solution. If you're powering from a battery, the voltage will drop; even an LDO regulator will be hard pressed to provide a regulated 12V when the battery voltage is in that vicinity.
30,058
If you really need 12 V from a source that is in the vicinity of 12 V, then you will probably need to use a boost/buck regulator that can handle input voltages both above and below the targeted 12 V output.
21,225
It is also the standard DC power supply voltage for Amateur Radio equipment.
hp1729
Joined Nov 23, 2015
2,304
For 13.8 V in and 12 V out consider just using three rectifiers in series to drop the voltage down.
dl324
Joined Mar 30, 2015
16,918
Yep, then LDO regulators are the way to go.
Unless the OP plans to trim the LDO, it may not give the precision he wants. Datasheet says 11.40-12.60V over the full temperature range. If the circuit will tolerate 5% supply variation, a couple diodes could be sufficient (when the battery is fully charged).
hp1729
Joined Nov 23, 2015
2,304
Of course. Always a given.
