Is there supposed to be a voltage drop after lm317t regulator (14volt as it input)..
Papabravo
Joined Feb 24, 2006
22,112
There will be a voltage drop across the regulator. This voltage drop times the current through the regulator is converted to heat, raising the temperature of the regulator. If the load has a low impedance, then the regulator may reduce the output voltage further, so that the output power will always be less than the input power.
38,830
The minimum voltage drop is 2-3V.
If you need to have less than that, you need a LDO (Low Dropout Regulator).
DickCappels
Joined Aug 21, 2008
10,661
The National/TI specification says the recommended operating condition is when Vin = Vout + 3V to + 40V. Any outside this range and you are on your own.
