How is this Lumberg 1503-02 3.5mm headphone socket supposed to be mounted to a PCB ?
freeflyer
Joined Sep 9, 2016
148
I am using a surface mount Lumberg 3.5mm headphobe socket (part number 1503 02)...
https://www.lumberg.com/en/products/product/1503+02
However, I don’t understand how this socket is supposed to be assembled to the PCB.
The legs at the front of the socket are 1.05mm above the board and the legs at the rear of the socket is 1.2nn above the board, so how is this supposed to be soldered to the PCB ?
Side view...
Front view...
Rear view...
Because of this, the PCB manufacture is unable to solder the socket to the board….
freeflyer
Joined Sep 9, 2016
148
It's designed to be mounted in a cutout in the board, to keep a low profile.
The datasheet does not make that abundantly clear.
I did wonder that but too late now as the PCB has been manufactured. The footprint in the datasheet is poor, it tells you nothing.
But it still does not make sense with a cut out, because the front legs are 1.2mm and the rear legs are 1.02mm. Unless is suppose to be at an angle which would be strange but the description does call it an angular version so maybe its supposed to be at an angle ?
But then what are the two plastic positining pins for ? Because if there is a cutout in the board, the position pins wont do anything ?
sghioto
Joined Dec 31, 2017
8,634
The board cutout would need to be large enough so the jack is resting on the solder pads.
Or again, manually solder to the pcb with a good blob of solder without bending the tabs.
Jon Chandler
Joined Jun 12, 2008
1,573
I suppose if you had a very thin device, you might want to angle the jack to give some clearance for the plug when the device is setting on a surface.
As to the protrusions, the thought just hit me...
Does the same plastic body come with contacts designed with longer legs to be mounted ON the board rather than IN the board?
freeflyer
Joined Sep 9, 2016
148
freeflyer
Joined Sep 9, 2016
148
Is still does not look right even with a cut out in the board. With the rear legs flush with the board, there is still a gap with the front legs.
Front view...
Side view....
Rear view...
Even if it were angled it still does not look right...
I've sent an email to the manufacturer but have not had a response.
FYI - this is a device that could go into production, so bodging it with wire, large solder blobs etc. is not a solution. Its a simple headphone socket, so it should simply fit to the board !
meth
Joined May 21, 2016
302
From intuition, maybe a rectangle cutout has to be made on the PCB so this part is lowered inside, and the "ear" lies flat on the pad?
Something that should be stated in the datasheet for the footprint, if true.
panic mode
Joined Oct 10, 2011
4,947
at first i thought like meth.... that cutout need to be T-shaped, wider at the rear contacts so that "U" part of the contacts drop into the cutout and only flat parts are on the top of PCB.
but then it hit me... that is wrong... cutout is rectangular... and those contacts fit to the BOTTOM side of the PCB. like below. the top side of the contacts is what faces PCB pads.
