LM2567 Switching Regulator - Heat Sink required...?
danielantonic
Joined Sep 22, 2019
68
Hello
I am making a power supply to power a Raspberry Pi/camera/touch screen (5V @3A), and some LEDs, servos/motors (12V LEDs and 9V servos/motors). I am using a 12V/5A adapter to supply power, and an LM2576 switching regulator to take the 12V down to 5V @3A for the pi etc. and a 7809 to drop 12V to 9V for the servos.
20210908_154518.jpgWhen I did my first test with the Raspberry Pi attached to 5V, it worked fine... beside the smoke starting to come from the regulator! I immediately turned it off and it still provides 5V at low loads, so I assume putting a heat sink on will fix my overheating problem... but I don't know if the ones I have are sufficient (recovered from old equipment). Could someone point me in the right direction please?
ericgibbs
Joined Jan 29, 2010
21,637
hi Daniel.
I would use this quick method.
Fix the LM2576 to the finned alloy heat-sink using leads as short as possible.
Run up the PSU, put it on load and measure the rise above ambient of the heat-sink.
From that information you can finalise the size of the sink. [hack saw]
E
danielantonic
Joined Sep 22, 2019
68
hi Daniel.
E
Thanks Eric. I gave that a try and just using that heat sink as pictured.
I hooked up my multimeter and measured the temperature as the Raspberry Pi booted up. The low power message kept popping up but the multimeter showed 5.08-5.12V the whole time, so I think there might be an issue with the Pi's onboard voltmeter.
The temperature slowly rose above ambient, and after 2 mins it was about 10 degrees celsius above ambient according to my laser thermometer (both on the regulator and the first capacitor), but touching it felt hotter... Reckon I should use some thermal paste or not really needed on something this small?
ericgibbs
Joined Jan 29, 2010
21,637
hi Daniel,
Thermal paste does help with the heat transfer from the Chip to sink, without paste there is trapped air, which is a poor heat conductor.
A 10Deg C rise is OK.
Also if possible, mount the fins vertically, improves the cooling air flow.
E
BTW: The LM2576 TAB body is connected to 0V, so no insulation for the heatsink is required,
danielantonic
Joined Sep 22, 2019
68
Thank you very much Eric! I am redoing my prototype board today, but I have found on the forums etc that the Raspberry pi 3 that I have takes 2.5A on its own, plus the 7" touchscreen that takes 550mA. Since this ads up to 3.05A, and I have other 5V peripherals to add, is there a way to get any more current from the LM2576, or is this a situation where you would get a second LM2576 and set it up in parallel...?
ericgibbs
Joined Jan 29, 2010
21,637
hi Daniel.
I would suggest a second LM2576 to supply a second 'group' of peripherals, also power up both LM's with the same power ON switch.
I would not connect the Vouts of the LM's together.
Ensure that LM's and all the peripherals have a common 0V.
If the heatsink can handle it, mount both LM's on the same sink.
E
