Livestrong LS10.0T "Connecting LS" displayed on console
pcampo
Joined Jan 16, 2019
10
I have a Livestrong LS10.0T "Connecting LS" displayed on console. Drive motor doesn't turn on nor does the incline motor. console buttons don't do anything. tested the drive motor and incline motors and they both work. Looking for some help to figure out whats wrong or what the next steps are. new to electronic troubleshooting but can follow direction for next steps
wayneh
Joined Sep 9, 2010
18,180
Have you looked through this ?: http://productload.johnsonfit.com/i...ce_guide/70a3ddccd64bcb35f9f2c679b0261ea0.pdf
pcampo
Joined Jan 16, 2019
10
-Checked the resistance of the DC drive motor which the manual calls to less than 10 ohms. reads 0 on my multimeter
-The console has no response when buttons are pushed, manual says if this happens to replace the console but i want to know its that before unloading the parts cannon
wayneh
Joined Sep 9, 2010
18,180
The 0Ω reading is probably fine unless your meter is a good one has a low ohms scale. You might check again and compare the reading you get to what the meter says when you hold its leads together. Try rotating the motor a bit as well. If it is truly a dead short, that could be a problem. If it appears to truly be 0Ω, try placing an incandescent lightbulb in place of the motor.
If the console is not responding, I suppose you cannot enter "engineering mode"? In the wiring diagram there are a number of connectors identified as "customer", meaning the customer is responsible for making those connections. I'd take them all apart, inspect, and put them back together. That may be a dead end but it's easy enough to try.
pcampo
Joined Jan 16, 2019
10
I retested the motor wires and got 0 ohms. Same reading for touching the 2 test leads together. Rotating the motor while testing shows infinite. Multimeter is a mastercraft 52-0055-6
As for the console wires, I had the issue before I had to take it all apart when I moved it to my house. Nothing looks burnt or off on the connector both at the console or the mcb
wayneh
Joined Sep 9, 2010
18,180
Hmmm, that zero ohm reading doesn’t feel right. Can you try using a light bulb in place of the motor?
Also, if the motor is disconnected, does the console come back to life?
pcampo
Joined Jan 16, 2019
10
Disconnecting the motor from the MCB did not bring the console back to life
Am I to be testing the wires connecting the motor to mcb or the wires inside the motor itself?
Juhstjahn
Joined May 10, 2019
Have you found a solution for this? I'm currently going through the same problem but don't want to spend the 260(CND) to replace the MCB incase I'm wrong
pcampo
Joined Jan 16, 2019
10
I found a used circuit board on Ebay and it fixes the issue. In my search I found a guy who would fix your board for 75 usd if you live in the USA. Add $30 if you're living in Canada. I will see if I can find the listing and post it here
Juhstjahn
Joined May 10, 2019
Thanks alot! I wish I knew what it was he changes/fixes on the board as I'm capable of doing it myself. Oh well! Appreciate your response, have a great day
cec4111
Joined Jan 16, 2020
9
I have a similar issue with Live strong 13.0T treadmill. It says CONNECTING and no response to the buttons on console. Did you get to resolve this issue? Where is the problem, control board or console? Please let me know.
pcampo
Joined Jan 16, 2019
10
I ended up finding a used control board which fixed the issue. So its somewhere in the control board that causes the issue but I dont know where. I did find a few sources on ebay or kijiji of people that would fix your old board with improved components. Let me know if you want me to look to see if I can find them and I can pass them along
cec4111
Joined Jan 16, 2020
9
Thanks that would be great. Please pass on the details. Also how much did you spend on the control board? Are they generic or should I buy the exact model?
Rawket51
Joined Jun 29, 2020
Hi all, thanks for this thread. This information was great.
cec4111 - did you ever get yours fixed? I'm having the exact same problem as you with the same treadmill, and I actually contacted the person mentioned by pcampo and he said he believes the problem is in the Upper Control Board and not fixable, requiring a brand new board. So in his words, I would need part 1000223785 instead of 1000111476 listed here: (https://parts.johnsonfitness.com/htm0926-01-ls13-0t-c2-tm439c-2012-2013)
cec4111
Joined Jan 16, 2020
9
Hi, If the error that shows on console is "Connecting LS" and both your motors work fine, then its an issue with Circuit Board, at least in my case. I shipped mine to the repair guys on Ebay and shipped back. It works fine and all costed $75USD.
