void NeoBit (int Bit) //It will not let me use just Bit
if (bit == 1)
LATBbits.NeoPin = 1
_delay(6)
LATBbits.NeoPin = 0
else
LATBbits.NeoPin = 1
_delay(3)
LATBbits.NeoPin = 0
#include "NeoCol.h"
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <xc.h>
uint8_t NeoGreen [NeoNum];
uint8_t NeoBlue [NeoNum];
uint8_t NeoRed [NeoNum];
void NeoBit (bool Bit);
bool bit_test(uint8_t Byte, signed char BitCount);
if (Bit == 1)
NeoPin = 1;
_delay(6);
NeoPin = 0;
else
NeoPin = 1;
_delay(3);
NeoPin = 0;
void NeoInit (void)
unsigned char NeoPixel;
for (NeoPixel = 0; NeoPixel < NeoNum; NeoPixel++)
if (NeoPixel < 10)
{ NeoGreen[NeoPixel] = 0; NeoBlue[NeoPixel] = 0; NeoRed[NeoPixel] = 64; }
else if ((NeoPixel >= 10) & (NeoPixel < 20))
{ NeoGreen[NeoPixel] = 0; NeoBlue[NeoPixel] = 64; NeoRed[NeoPixel] = 0; }
else if ((NeoPixel >= 20) & (NeoPixel < 30))
{ NeoGreen[NeoPixel] = 0; NeoBlue[NeoPixel] = 64; NeoRed[NeoPixel] = 64; }
else if ((NeoPixel >= 30) & (NeoPixel < 40))
{ NeoGreen[NeoPixel] = 64; NeoBlue[NeoPixel] = 0; NeoRed[NeoPixel] = 0; }
else if ((NeoPixel >= 40) & (NeoPixel < 50))
{ NeoGreen[NeoPixel] = 64; NeoBlue[NeoPixel] = 0; NeoRed[NeoPixel] = 64; }
else if ((NeoPixel >= 50) & (NeoPixel < NeoNum))
{ NeoGreen[NeoPixel] = 64; NeoBlue[NeoPixel] = 64; NeoRed[NeoPixel] = 0; }
void NeoDraw (void)
signed char BitCount;
for (BitCount = 7; BitCount >= 0; BitCount--)
NeoBit(bit_test(NeoGreen[NeoPixel], BitCount));
NeoBit(bit_test(NeoRed[NeoPixel], BitCount));
NeoBit(bit_test(NeoBlue[NeoPixel], BitCount));
NeoPin =0;
void NeoRotate (void)
unsigned uint8_t NeoPixel;
for (NeoPixel = 0; NeoPixel < NeoNum - 1; NeoPixel++)
NeoGreen[NeoPixel] = NeoGreen[NeoPixel + 1];
NeoBlue[NeoPixel] = NeoBlue[NeoPixel + 1];
NeoRed[NeoPixel] = NeoRed[NeoPixel + 1];
NeoGreen[NeoNum - 1] = NeoGreen[0];
NeoBlue[NeoNum - 1] = NeoBlue[0];
NeoRed[NeoNum - 1] = NeoRed[0];
return ((Byte >> BitCount) & 0x01);
void main()
NeoInit ();
while(1)
NeoDraw ();
NeoRotate ();
__delay_ms (25);
// PIC18F2550 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config PLLDIV = 1 // PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1 // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator (HS))
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3 // Brown-out Reset Voltage bits (Minimum setting 2.05V)
#pragma config VREGEN = OFF // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config WDTPS = 128 // Watchdog Timer Postscale Select bits (1:128)
// CONFIG3H
#pragma config CCP2MX = ON // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <pic18f2550.h>
#include <xc.h>
#define _XTAL_FREQ 40000000
#define NeoPin LATBbits.LATB0
#define NeoNum 4
#define ALL_OUT 0x00
#define ALL_IN 0xFF
For some unknown reason you remove some important C syntax at the end of several lines. This usually results in an error flood.This still not right
View attachment 144506Code:void NeoBit (int Bit) //It will not let me use just Bit { if (bit == 1) { LATBbits.NeoPin = 1 _delay(6) LATBbits.NeoPin = 0 } else { LATBbits.NeoPin = 1 _delay(3) LATBbits.NeoPin = 0 } }
/home/burt/code/ws8test/NeoCol.c:11: error: (195) expression syntax
/home/burt/code/ws8test/NeoCol.c:11: error: (194) ")" expected
/home/burt/code/ws8test/NeoCol.c:11: error: (249) probable missing "}" in previous block
/home/burt/code/ws8test/NeoCol.c:11: error: (285) no identifier in declaration
/home/burt/code/ws8test/NeoCol.c:11: error: (314) ";" expected
/home/burt/code/ws8test/NeoCol.c:17: error: (285) no identifier in declaration
/home/burt/code/ws8test/NeoCol.c:17: warning: (374) missing basic type; int assumed
/home/burt/code/ws8test/NeoCol.c:17: error: (314) ";" expected
/home/burt/code/ws8test/NeoCol.c:23: error: (285) no identifier in declaration
/home/burt/code/ws8test/NeoCol.c:23: warning: (374) missing basic type; int assumed
/home/burt/code/ws8test/NeoCol.c:23: error: (314) ";" expected
/home/burt/code/ws8test/NeoCol.c:51: error: (183) function or function pointer required
/home/burt/code/ws8test/NeoCol.c:51: error: (981) pointer required
/home/burt/code/ws8test/NeoCol.c:53: error: (183) function or function pointer required
/home/burt/code/ws8test/NeoCol.c:53: error: (981) pointer required
/home/burt/code/ws8test/NeoCol.c:55: error: (183) function or function pointer required
/home/burt/code/ws8test/NeoCol.c:55: error: (981) pointer required
/home/burt/code/ws8test/NeoCol.c:57: error: (255) not a member of the struct/union ""
/home/burt/code/ws8test/NeoCol.c:57: error: (183) function or function pointer required
/home/burt/code/ws8test/NeoCol.c:57: warning: (1385) variable "RB0" is deprecated (declared at /home/burt/code/ws8test/NeoCol.c:57)
/home/burt/code/ws8test/NeoCol.c:57: error: (981) pointer required
/home/burt/code/ws8test/NeoCol.c:57: error: (182) illegal conversion between types
int -> volatile union S107
/home/burt/code/ws8test/NeoCol.c:65: warning: (373) implicit signed to unsigned conversion
/home/burt/code/ws8test/NeoCol.c:66: warning: (373) implicit signed to unsigned conversion
/home/burt/code/ws8test/NeoCol.c:67: warning: (373) implicit signed to unsigned conversion
(908) exit status = 1
nbproject/Makefile-default.mk:106: recipe for target 'build/default/production/_ext/1693387515/NeoCol.p1' failed
make[2]: Leaving directory '/home/burt/code/ws8test'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory '/home/burt/code/ws8test'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 492ms)
The if line should have Bit with a capital B, the variable, not the data type.For some unknown reason you remove some important C syntax at the end of several lines. This usually results in an error flood.
What's important first is error: (314) ";" expected
That too.The if line should have Bit with a capital B, the variable, not the data type.
It's driving a three colour LED?It's really making color I should say because there only red blue green so it making white blue
Oh, I see._delay(3); _delay(constant)' to delay for the specified number of instruction cycles
Thanks to AlbertHall for pointing that out.
Where is NeoNum assigned a value?
In the NeoCol.h file
I looked at the LED datasheet and it makes a bit more sense now - it is an 'intelligent' LED!Well I guess it's not working LOL
250uS is way wrong.Its showing a 250us high
