Lithium ion battery - detached wire
doubtb
Joined Nov 11, 2020
Hello
Tried to search the forums, but i dont think i saw anything related to my question. Appologies if it has. I had to replace a battery on a laptop and i noticed that one wire was disconnected from the battery back. Is this an issue? Not knowing much about batteries and i'm wondering if this is a fire hazard. I've attached a picture in question. Thank you in advance for your responses.bttry.jpg
Irving
Joined Jan 30, 2016
5,109
Its not a fire hazard in itself, the battery isn't going to blow up or do anything stupid, however there are three red wires for a reason - to supply sufficient current to the laptop. There's usually a good margin for error in these things but I'd certainly make sure there's no possibility of the broken end shorting on anything first and then check after using it for a while that the other red wires aren't getting too hot.
Was this a replacement battery or what? How did it get damaged?
doubtb
Joined Nov 11, 2020
Thank you for the response. The original Toshiba battery died and this was the replacement battery. As soon as i took it out of the package, i noticed the detached wire. The new battery works, but the detached wire was my concern.
Dodgydave
Joined Jun 22, 2012
11,395
Looks like there are 3 Black wires too, so I would confirm that the extra wires are for better current draw, the other colours are for cell monitoring during charging.
