Linear circuit explanation
dl324
Joined Mar 30, 2015
18,328
Oh ok, got it. Moderator, you can delete this if you want...(it's pointless)
Circuit in question:
There's a little more to it than that. The output of the top opamp is always going to be greater than 1/1000 of the input whenever there's a load.
If you look at the feedback loop, the bottom opamp is a voltage follower sampling the voltage across the load. It's output is fed into a difference amplifier that's subtracting the voltage across the load from the voltage across the 10M resistor+load. That output is fed back to the top opamp so it can keep the voltage across the 10M resistor 1/1000 of the input voltage.
