Line Regulation LDO
Michel_e_r
Joined May 30, 2008
11
This is not really for homework other than for my own learning as a hobbyist, but I'll post anyway in hopes someone could clarify my confusion.
I'm just checking out some LDOs and did line regulation test on it. I've captured the data below:
I've seen datasheets that state line regulation in terms of mV/V (meaning that some amount of mV changes per 1V) and everywhere I read that the formula for line regulation = change in Vo/change in Vin. By "Change in Vo", does it mean take biggest value measured - smallest value measured from the "Vout (mV)" column? In other words would I calculate this as (Line regulation = (Vo max measured - Vo min measured)/(1.98 - 1.66))? Or do I take each line as a change of voltage from the previous row and then do an average of all calculated values?
Just curious how this term is represented.
BobTPH
Joined Jun 5, 2013
11,633
Your table not showing a systematic error based on input voltage, it is showing random fluctuations. I would use a wider range of input voltages, starting from tle expected output + the dropout voltage and going up the the maximum input voltage. Then you might see a trend.
