Hi all,
I have a 12vdc proportional coil which is controlled using a logic level N-channel enhancement MOSFET (FQP30N06L). Please see attached spec sheet for both and my circuit diagram.
In order to obtain proportionality I vary the current between 100mA and 1200mA using PWM control of the Mosfet Gate. At 100% PWM duty cycle the coil draws about 4A. I would like to limit the maximum current the coil is able to draw @ 1.2amps. I know I can do this via PWM, but then I wouldn't be driving the MOSFET gate as hard as it requires and as such heat dissipation is a problem and reliability is shocking.
So, I am thinking of using something like an LM317, LM338, or LM2930T configured as a current controller to achieve this. Given my voltage and current requirements can anyone recommend a suitable IC with accompanying circuitry / configuration? I want to keep heat to a minimum is possible.
Thanks in advance.
Jim
Thanks in advance.
Jim
