Hey... You...Your condensed version wasn't helpful. I bit the bullet and read your first post.
The second paragraph described your project.
If you want it to be something you'd be proud of, using that dual USB cigarette is going to look like a hack. If I was to do something like this, I'd make a faceplate that fit well in the opening. I'd find a way to disassemble the USB thing you have to make them look like they were designed for the faceplate.
You're not going to be able to measure the battery voltage of anything you're charging. And the USB charging devices don't have a charging indicator.
Displaying the car battery voltage (when the vehicle isn't running) or the regulator voltage is more realistic.
Color makes a difference because forward voltage is different for each color. We also need to know the maximum DC current they're designed for.
The most common way to power LEDs is to use a current limiting resistor. If you use multiple LEDs and you want them to appear to be the same brightness, you need to use a current source; because the forward voltages of the same color LED from the same batch isn't tightly controlled.
That was useful information! Thank you. And FYI...
I bought a piece of 1/16" abs plastic. One side is baby butt smooth and the other looks like pretty much any other panel. I think they called it "skin cell" or something oddly.
But yes my reason in coming and asking is because I want it to look as natural as the original piece that was there. Which was a small digital clock.
Certainly trying to avoid the hack job as you call it. I refuse to do this any way but the proper and best looking way. If I don't get answers here I will get it somewhere.
Note the white space!
